burnin oil in vtec.....please help
Old May 13, 2004 | 04:22 PM
slammin86's Avatar
Default burnin oil in vtec.....please help
i have a 99 civic si with a gsr bottom end, b16 top end, and type r cams. im makin decent hp and torque considerin my low compression from the b16 head.
problem is, it burns oil like a **** while in vtec. if im drivin it pretty hard it will go through like a quart in 100 miles, but if i drive like a normal person and never hit vtec, it doesnt burn any.
first thought was rings.....but i checked the compression and it hadnt changed. and rings would smoke all the time, not just in vtec, correct?
im thinkin it must be the valve seals....any other opinions as to what it could be?
has anyone had the same problem?
Old May 13, 2004 | 06:43 PM
99B16Si's Avatar
if your rings or seals are worn it wont necessarity smoke all the time. when u rev it higher under WOT your puting a lot more load on the motor and more pressure on those worn seals.
do a leakdown test and it will tell you whats wrong.
Old May 13, 2004 | 09:31 PM
mugenracer's Avatar
definitely rings, my last teg burned gallon loads of oil between services (6 or 7 liters) and it only smoked at high revs, turned out the rings were toast. The valve seals were actually like new but i replaced them anyway, never burned a single drop after that!
Old May 14, 2004 | 03:18 AM
slammin86's Avatar
Default Re: (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">definitely rings, my last teg burned gallon loads of oil between services (6 or 7 liters) and it only smoked at high revs, turned out the rings were toast. The valve seals were actually like new but i replaced them anyway, never burned a single drop after that!</TD></TR></TABLE>
so was it rings or was it valve seals?
Old May 14, 2004 | 07:38 AM
99B16Si's Avatar
rings....duh
Old May 14, 2004 | 07:55 AM
MrBui's Avatar
Default Re: (99B16Si)
its actually normal for vtec motors to burn oil.....
Old May 14, 2004 | 08:20 AM
Malgerus's Avatar
Default Re: (n20need4vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n20need4vtec &raquo;</TD></TR><TR><TD CLASS="quote">its actually normal for vtec motors to burn oil.....</TD></TR></TABLE>
Not that much!
Black R
Mar 28, 2011 05:42 PM
Swapped94
Jan 12, 2009 04:54 PM
2gen_tegs_rule
Jul 2, 2008 03:17 AM
humboldt_skim
20
May 31, 2008 12:25 PM
customx_
Mar 18, 2003 05:56 AM
