Any other Si Preludes on here running stock boost?
I just got the DragGenIII kit with the Tial wastegate.
I've learned my exhaust manifold is leaking bad due to an old gasket gone bad.
but still only getting 3psi... you guys see a low boost on your stock kits too?
Yes it does.
The II Gen kit has been updated to the III with better fitting IC piping, blowoff valve (but its still hard as crap to install)
about a month old.
about a month old.
Ask Ben at importparts whether or not the Gen III exists for preludes. It doesn't. Shops just tell people it does. There has been no change in manifold design. Without a change in manifold design, the intercooler piping HAS to be routed the way it is, unless you like cutting up your car.
The quality of fitting of each Drag kit is slightly different. They are made by hand, and there is human error.
All Drag kits have bov's.
11psiTurboSI
May 6, 2004 08:21 AM
