Why do people rag on Drag Manifolds?
Re: Why do people rag on Drag Manifolds? (jdmjay04)
2 Reasons:
1. They crack.
2. Wastegate placement isn't optimal.
I don't have pictures of mine, but it cracked in two places and I welded it back up.
1. They crack.
Had mine for a almost 2 years no problems yet.The kit on my stock gsr put out 259.9whp 191.2tq till i can get a lovefab.
Re: Why do people rag on Drag Manifolds? (MadCow)
my first manifold was cracked. It cracked everywhere and someone welded it up. Then it held a lil then started cracking again. Then went to Jotech bought a revhard. Not the best but still hasnt cracked
Re: Why do people rag on Drag Manifolds? (redturbocivic)
My Gen 2 manifold cracked everywhere possible. Welded up one spot another one would pop up later. Not sure if the problems been fixed in the DRAG 3/4 manifolds but both of them I had spider-webbed where the logs met.
Re: Why do people rag on Drag Manifolds? (iiilgsrlll)
the design on the drag GEN 3 and 4 manifolds is MUCH better as far as cracking goes and if it does crack they replace it for free. the wastgate placement still sucks tho and has problems with gradual boost and boost spikes. I know alot of guys do some mild porting on that sport and they say it fixed the problems. also the deltagate isn't the best and this further hinders the placement of the wastegate
Exactly...it isnt the cracking as much as the wastegate placement which leaves much to be desired.
Not a huge deal, but not ideal. I havent seen any spiking issues with my 60mm exhaust on.
my drag gen 2 manifold is 4 years old,has over 40,000 miles on it and is on its second engine ..no problems here..
Re: Why do people rag on Drag Manifolds? (D-Man)
i made 326 to the wheels on a drag manifold and im still using it. i plan on making 450-500 witrh this manifold. of course im upgrading frag turbo and intercooler to bigger pieces
Re: Why do people rag on Drag Manifolds? (newgsrdriver)
Yup, the wastegate placement sucks. If there's a decent amount of backpressure you'll be fine. Just wait till you step upto a larger exhaust. A friend used to run a 3" dp and 3" exhaust and the lowest boost it could hold was a bar..
-Mike
-Mike
My friend had a Drag manifold on his 2000 B18c5 2.5" downpipe flared to 3.0". It spiked from 9lbs to 15lbs. He went to an Inline Pro manifold (nothing else) and had no problem with the boost spiking.
The thing about most people on Honda-tech is they go off here say alot and they tend to love the band wagon approach.
Re: Why do people rag on Drag Manifolds? (TurboR1391)
This wasn't hear say This happened multiple times in-front of VaporTrail, Enthalpy, some other people and I. I know VaporTrail and Enthalpy have seen it mroe than a couple times though.
Re: Why do people rag on Drag Manifolds? (0x64)
Mine will hold boost with a 2.5"-3" dp and 3" exhaust, but if I run open downpipe it spikes to 15psi. No cracks though with 3 years of use, so I am happy
They could be cracking due to a lean condition or also due to no flex pipe on dp so as motor torques back there's no give in the the exhaust system. Mine has no cracks, been running for 6 months now. It made 259 whp 211 lbs, setup's in my sig. I'll be selling mine soon, just don't like they way it looks and upgrading the turbo so I got the inline pro manifold. I'll be running full race mani in near future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">This wasn't hear say </TD></TR></TABLE>Don't be so defensive. I know someone who had a a Drag Manifold crack, but it was on the old kit. If I offended you I'm sorry. You've been on Honda-tech long enough to know that most people on here go with the wind when it comes to opinions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCow »</TD></TR><TR><TD CLASS="quote">2 Reasons:
1. They crack.
I don't have pictures of mine, but it cracked in two places and I welded it back up. </TD></TR></TABLE>
Thats exacly the right answer to his question right there. I used to have one - didnt crack. But alot of people have. Id have to say the number of cracked manifolds are pretty low since there is about a billion drag manifolds in circulation.
Id say their biggest problem is the wastegate placement (ie off #1 runner). Its not optimal.
liam
1. They crack.
liam
I wasn't offended Just clearing up why I posted so no one would think another post about a "friend"
Re: Why do people rag on Drag Manifolds? (calib17a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calib17a »</TD></TR><TR><TD CLASS="quote">They could be cracking due to a lean condition or also due to no flex pipe on dp so as motor torques back there's no give in the the exhaust system.</TD></TR></TABLE>
also..they could crack from not using the honda 2-piece exhaust manifold gasket...bolting it straight on with no gasket is a no no.
Another thing for spiking people ive seen around here were using a deltagate wastegate. But as soon as they switch to a TIAL no probs.
I know that if i do a 3" exhaust with not cat it will spike. Im doing a 2.5"DP to a 3" exhaust and with a 3" cat i do not think ill have any probs i also use a TIAL waste gate.
mine use to spike, went with tial wastegate it helped a little
but now i ported the runner where the wastegate flange is, it holds 14psi all the way to redline with open downpipe
no cracks yet
no cracks yet
Re: Why do people rag on Drag Manifolds? (ek9turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9turbo »</TD></TR><TR><TD CLASS="quote">mine use to spike, went with tial wastegate it helped a little
no cracks yet</TD></TR></TABLE>
Do you have any pictures as to the extent of your porting?
