B&M fuel psi gauge, anyone have problems with it ?
If you peg it, you'll break it. I've done it before on accident when I had a vacuum leak, didn't know it, found and fixed it, but forgot to decrease the rail pressure. It pegged it when I started the car and from that point on, it wouldn't read correctly or steadily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">If you peg it, you'll break it. I've done it before on accident when I had a vacuum leak, didn't know it, found and fixed it, but forgot to decrease the rail pressure. It pegged it when I started the car and from that point on, it wouldn't read correctly or steadily.</TD></TR></TABLE>
Will that happen to any gauge ?
I'd imagine so, to a certain extent.
A friend once pressure tested his charge and intercooler piping with 50psi of line pressure coming out of the compressor and it pegged his mechanical boost gauge. It read slightly off after that, but it wasn't permanently damaged to the point of not even moving smoothly with pressure transients like my fuel pressure gauge.
I've got two mechanical fuel pressure gauges. One on the fuel filter and the other on the fuel rail (AEM). The one on the rail reads about 2psi lower than the one on fuel filter. That seems like an appropriate amount of pressure drop.
I had one on my accord. Had to replace it twice because it kept giving me fucked up readings. Replace it with a liquid filled gauge and youll be fine. The non liquid filled gauges seem to not be able to take the vibration from the engine. You can find the liquid filled ones just like the b&m ones on http://www.summitracing.com for like 20 bucks.
Just search for liquid filled fuel pressure gauge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord91h22 »</TD></TR><TR><TD CLASS="quote">I had one on my accord. Had to replace it twice because it kept giving me fucked up readings. Replace it with a liquid filled gauge and youll be fine. The non liquid filled gauges seem to not be able to take the vibration from the engine. You can find the liquid filled ones just like the b&m ones on http://www.summitracing.com for like 20 bucks.
I was looking at the autolink one, seemed pretty good. But then I got a deal on a b&m but I might stick with autolink, thanks for all the help guys. Any other people that want to chim in feel free.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy »</TD></TR><TR><TD CLASS="quote">The only thing I've heard of going bad on the B&M's is giving weird Fuel pressure readings</TD></TR></TABLE>
98civic94gsr
May 2, 2006 03:54 PM
