Top of block scratched lightly, can this be fixed?
Old Nov 6, 2001 | 09:33 AM
Chuji's Avatar
Default Top of block scratched lightly, can this be fixed?
I have an LS bottom end that is scratched and scuffed lightly across the top of the block. Will this cause a problem with the headgasket not sealing correctly? Can I shave the block to fix this? Thanks
Old Nov 6, 2001 | 09:45 AM
rioninja's Avatar
Default Re: Top of block scratched lightly, can this be fixed? (Chuji)
If its not bad, you can deck the block. Also, if the gash is pretty deep you can get it welded at a machine shop before they deck it. Should cost less than $100.
eg:R
Apr 19, 2014 08:56 AM
10SecDSM
Sep 15, 2006 08:11 AM
West Werks
21
Aug 9, 2004 10:36 PM
