tps sensor problems...what do you think?
Old May 13, 2004 | 01:45 PM
hondaeg8's Avatar
Default tps sensor problems...what do you think?
i had to put a new tps sensor on my motor. when driving normal, everything is fine.
when i get on it, the check engine light comes and it throws code 7, tps sensor.
why does it do this?
Old May 14, 2004 | 03:47 AM
civic-4-ges's Avatar
Default Re: tps sensor problems...what do you think? (hondaeg8)
Did you set the tps voltage when replacing it??
Old May 14, 2004 | 05:41 AM
degooser's Avatar
yah you need to check the voltage on that biatch...its like a distributor and it needs some fine tuning...the voltage is somewhere on h-t...to a search on tps archived that is..
Old May 14, 2004 | 05:56 AM
Default Re: tps sensor problems...what do you think? (degooser)
around .5v with tb plate closed, around 4.5-5 with wide open
Old May 14, 2004 | 10:10 AM
hondaeg8's Avatar
alright...i'll check it out.
thanks
Old May 14, 2004 | 10:23 AM
Donkey85's Avatar
correct info
Domin8rzCB7
Feb 9, 2019 02:37 PM
airikkCRX
Apr 25, 2010 11:23 AM
team 15
Mar 13, 2007 12:00 AM
MassScene
Apr 27, 2004 05:08 PM
