B16 civic is SLOW
Old May 13, 2004 | 11:53 AM
phat_gsr98's Avatar
Default B16 civic is SLOW
literally i can run down the road faster than it.
i just swapped in the b16, the car was one of those gay dual port injection things b4 so i think i might have screwed up LARGELY on my wiring.
anybody have any ideas what I should check over???
Old May 13, 2004 | 12:06 PM
The AntiRice's Avatar
Default Re: B16 civic is SLOW (phat_gsr98)
Everything?
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phat_gsr98 &raquo;</TD></TR><TR><TD CLASS="quote">anybody have any ideas what I should check over???</TD></TR></TABLE>
the wiring. check 3x before you cut or soilder
Old May 13, 2004 | 01:48 PM
wpgcivic's Avatar
dude its called mpfi, research it
Old May 13, 2004 | 02:01 PM
phan's Avatar
Default Re: (wpgcivic)
are you throwing any codes?
Old May 13, 2004 | 02:13 PM
phoenixb16aguy's Avatar
Default Re: (phan)
make sure you vtec silinoied is hooked up properly, also you may need a new resistor box, also you might just have bad injector's when you swap,specially a jdm motor always change plugs wires cap and rotor if nessecary, injectors and dont run synthetic oil run cheap oil for 500 miles and change it cause these engine have been sitting for a year at least and have build up inside the egnine, well keep us updated
Old May 13, 2004 | 02:23 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: (phoenixb16aguy)
My car is running properly and it's still slow. 1.6L can only do so much
Old May 13, 2004 | 03:31 PM
phat_gsr98's Avatar
Default Re: (SeaBass)
i checked over all my wiring and its dead onto the directions i have,
and for whoever said do a search, i have and i have all the wiring right so don't just post up SEARCH.
anyone have a link to instructions i want to see if they match what i have.
also if i unbolt the fuel rail and turn the car over will that show me if my injectors are working if i aim them in the air
Old May 13, 2004 | 03:32 PM
phat_gsr98's Avatar
Default Re: (phat_gsr98)
oh and it also backfires pretty loud and a lot when you rev it up a bit.
Old May 13, 2004 | 03:36 PM
spaceman's Avatar
tune-up...check timing,grounds,etc...archived search
Old May 13, 2004 | 03:42 PM
b16_madman's Avatar
Default Re: (spaceman)
mine's swapped right and it's slow too, 15.3 doesn't scare many people it's loaded w/junk though
Old May 13, 2004 | 03:49 PM
2point2's Avatar
Your from guelph? i can have a look at that this weekend if you want.. but it'll cost ya..
Old May 13, 2004 | 04:11 PM
EL Vap133's Avatar
Default Re: (phan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phan &raquo;</TD></TR><TR><TD CLASS="quote">are you throwing any codes?</TD></TR></TABLE>
Old May 13, 2004 | 04:15 PM
Boosted Chemist's Avatar
buy a snail then youll<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman &raquo;</TD></TR><TR><TD CLASS="quote">mine's swapped right and it's slow too, 15.3 doesn't scare many people it's loaded w/junk though </TD></TR></TABLE>
add a snail to the equation and
boost is key
Old May 13, 2004 | 04:25 PM
phat_gsr98's Avatar
Default Re: (Mad Chemist)
just checked and im throwing 4, 10, 14
Old May 13, 2004 | 05:51 PM
2point2's Avatar
You didn't hook up the CKP Sensor (Crankshaft Position Sensor) right code 4
and you have the IAT Sensor (Intake Air Temperature) and IAC Valve (Idle Air Control) switched around or unpluged. &lt;-- this will cause what you are describing. I did this once, the easy way is to look at a friends ef and see if you have the wiring colors matching up with those sensors. if i'm right (i'm pretty sure i am about code 10, 14) you owe me a coffee
Old May 13, 2004 | 06:44 PM
phat_gsr98's Avatar
Default Re: (2point2)
come to think about it I know you are right with out even looking at it about 10 the iac and iat.
Old May 13, 2004 | 06:55 PM
2point2's Avatar
Tripple, Tripple.
Old May 13, 2004 | 08:30 PM
daidilus's Avatar
http://www.geocities.com/c_rexboy/mpfi.html
Old May 14, 2004 | 06:13 AM
wpgcivic's Avatar
Default Re: (daidilus)
yeah man with those codes u mad screwed up on the wiring, get someone who knows what they are doing fix it up for you, i did the same and had those codes when i did mpfi and back fired from the intake and all this, and was slow as ****,
get someone to do ur wiring and u'll be fast once again...
Old May 15, 2004 | 04:03 PM
phat_gsr98's Avatar
I know how to do my own wiring thanks
thanks daidilus, i compared that to what i had and 2 wires are different im gonna go check now.
I will keep an update.
Old May 19, 2004 | 07:04 PM
phat_gsr98's Avatar
changed what needed to be changeed
is it possible the disty is no good?? still getting crank angle sensor code
Old May 20, 2004 | 07:12 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phat_gsr98 &raquo;</TD></TR><TR><TD CLASS="quote">changed what needed to be changeed
very possible.. I've done the dist on both my ZC's and my buddy has had the same problem with his b16a. Always a great idea to try out a buddies dist when a CEL hits.
Old May 20, 2004 | 07:14 AM
virginia_dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaBass &raquo;</TD></TR><TR><TD CLASS="quote">My car is running properly and it's still slow. 1.6L can only do so much </TD></TR></TABLE>
I got a B16 and a Y-1 tranny and its ain't slow by any stretch of the word.
Old May 20, 2004 | 08:19 AM
kyle h.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phat_gsr98 &raquo;</TD></TR><TR><TD CLASS="quote">B16 civic is SLOW</TD></TR></TABLE>
old news
builtb16civic
Jan 19, 2013 01:42 PM
rad32
16
Aug 4, 2009 03:24 PM
Layziejoe775
Jan 25, 2008 08:19 AM
EM1-23
May 13, 2007 01:36 PM
