Desperate: Procedure to adjust valve timing, What specs?for stock/ or for turbo
Old May 13, 2004 | 09:45 AM
btrim23's Avatar
Default Desperate: Procedure to adjust valve timing, What specs?for stock/ or for turbo
I thank you all for helping, First of all, after replacing the head gasket and the valve stem seal, My car don't seem to start. timing belt time is set correctly, I'm figuring that it could be the valve that is too tight. So your help on procedures to adjust the valve timing and its specs. Plus should it be any different for the specs if it's a turbo h23a? your help please......
Old May 13, 2004 | 10:16 AM
Sephro's Avatar
Default Re: Desperate: Procedure to adjust valve timing, What specs?for stock/ or for turbo (btrim23)
Check out the stickies. Especially .: Essential Prelude Links |::.
This should have everything you want to know..
https://honda-tech.com/zerothread?id=618786
Old May 14, 2004 | 10:36 AM
btrim23's Avatar
thanks, I'll look. anyone else can help?
journeyquest
Jul 10, 2011 12:34 PM
euG3dc2r
Feb 23, 2005 03:45 AM
555R
Jan 11, 2005 05:46 PM
SH LUDE
Oct 28, 2002 08:22 PM
