Distributor oil leak
Old May 13, 2004 | 05:05 AM
4hondas's Avatar
Default Distributor oil leak
How is the distributor sealed from the engine on the 93 1.6L EX coupe. My engine has had an oil leak for some time, and despite replacing the valve cover gasket, it still leakes. It looks to be comming from the distributor end of the engine. That makes sense because I've had a problem on two occasions where one position inside the distributor cap was fouled causing the engine to run rough (on three cycliders). Does the distributor shaft have a seal internal to the housing, and could that be replaced (reuild kit?) without having to buy a new distributor? Could it be possible that the leak is not internal to the distributor, but external and that oil just got under the distributor cap from the outside? What am I getting myself into? I have some experience with cars but am not a mechanic by trade.
Old May 13, 2004 | 05:10 AM
saleensolution's Avatar
Default Re: Distributor oil leak (4hondas)
if im not misataken there like a brass brearing at the end of the dis. mine wore out and had to get a new dis. because it ate out the housing
themiz816
Apr 28, 2013 07:16 PM
blacktibby07
11
Feb 5, 2011 03:12 PM
blackmfoggie
Aug 23, 2007 12:09 PM
sonson6
Mar 20, 2007 07:56 PM
porsche997dc2
Dec 22, 2003 05:14 PM
