blown headgasket but good compression results?
Old May 13, 2004 | 04:22 AM
an2ny888's Avatar
Default blown headgasket but good compression results?
i've been slowly losing coolant on a regular basis, so i did a compression test and got 240 psi across the board. does this automatically rule out a bad headgasket? or is it possible to have good compression results even with a bad headgasket? i checked my coolant and oil and they both look clean
Old May 13, 2004 | 04:52 AM
Jon D's Avatar
Default Re: blown headgasket but good compression results? (an2ny888)
Hmmmm.....if your still receiving good compression across the board i would tend to think that its not the head gasket.
Old May 13, 2004 | 04:55 AM
DragII's Avatar
25 Year Member
no oil in coolant either? I'd look for a leak
Old May 13, 2004 | 06:35 AM
an2ny888's Avatar
Default Re: blown headgasket but good compression results? (DragII)
believe me i looked for a leak. i even changed the radiator, didn't help. someone told me its possible to have a slight headgasket leak, without the usual symptoms like milky oil and overheating. dunno if its true, but i'm thinking that might be whats happening in my case.
Old May 13, 2004 | 08:44 AM
SOUNDEFFECTS's Avatar
its possible that the coolant could leak into the oil gallerys throught the headgasket but not too common. What kind fo headgasket? stock?
Also coolant could leak into the oil pan through the bottom of the sleeves if they are aftermarket
Old May 13, 2004 | 08:50 AM
CRITTERMATT's Avatar
Check your water pump. I kept smelling coolant after I would drive my car. I looked everywhere for a leak. It was loosing coolant also. When I changed my timing belt and water pump, I found out that the pump was leaking. It would be almost impossible to see it. look around the side of your timing belt cover on the rear of the engine. You might see some coolant there.
Old May 13, 2004 | 02:14 PM
vtec.dc2's Avatar
coolant pressure test could narrow down location of the leak. you can also get it done at dealer for $30-40, hopefully its nothing cracked internally. look around/under the car, anywhere along coolant lines, radiator for leaks.
Old May 14, 2004 | 06:51 AM
an2ny888's Avatar
Default Re: blown headgasket but good compression results? (vtec.dc2)
im using the stock headgasket. will check again, thanks for all the help
Old May 14, 2004 | 07:50 AM
The Toecutter's Avatar
You may want to check the intake manifold where the coolant passage connects to the head. I've had a leak there before and the engine was actually consuming small amounts of coolant. The gasket was bad.
Old Jul 4, 2008 | 06:05 AM
heel_touge's Avatar
Default Re: blown headgasket but good compression results? (The Toecutter)
back up. billowing out a chalky white/rich smelling smoke at full throttle and can't really smell sweetness.
was there ever a solution to this thread?
checked compression yesterday
1:255
2:250
3:250
4:255
*have noticed resvoir empties quickly. but it isn't the oem unit.
*car does not overheat. nor has it ever since i have owned it.
*OEM head gasket.
*hondata IM gasket
*checked exhaust pipe, only soot and condensation. wouldn't there be a light oil film in there if it is bad rings?
any insight would be fannn tastic.
Modified by heel_touge at 3:12 PM 7/4/2008
Modified by heel_touge at 3:13 PM 7/4/2008
Old Jul 4, 2008 | 06:19 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: blown headgasket but good compression results? (heel_touge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heel_touge &raquo;</TD></TR><TR><TD CLASS="quote">back up. billowing out a chalky white/rich smelling smoke at full throttle and can't really smell sweetness.
1:255
2:250
3:250
4:255
*OEM head gasket.
*<U>hondata IM gasket</U>
Modified by heel_touge at 3:13 PM 7/4/2008</TD></TR></TABLE>
i would check that for a leak, also a leakdown test would be more accurate for a blown headgasket as sometimes the leak is so minor that it will only do it at high rpm's
Old Jul 4, 2008 | 07:06 AM
cxSHOE's Avatar
go to autozone, rent the "block tester" then buy the blue fluid that goes with the device. about 30-40 to rent. and you pay $10 for the liquid. talk to the manager because majority of the young kids at the counter will not know wtf your talking about...
cylinder device that goes over the coolant opening, and the blue liquid inside device will turn yellow or stay blue.
blue liquid will turn to yellow if you have a blown headgasket.
how does this work??
gases from the engine escape into the antifreeze ( a bubble in other words) and the device picks up the gases then changing the fluid from blue to yellow.
Modified by cxSHOE at 8:21 AM 7/4/2008
Old Jul 4, 2008 | 07:39 AM
heel_touge's Avatar
Default Re: blown headgasket but good compression results? (cxSHOE)
ooooooh that sounds like it would do the trick.
Old Jul 4, 2008 | 07:40 AM
heel_touge's Avatar
Default Re: blown headgasket but good compression results? (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">
i would check that for a leak, also a leakdown test would be more accurate for a blown headgasket as sometimes the leak is so minor that it will only do it at high rpm's</TD></TR></TABLE>
there was a leakdown test performed a few months ago, while it was smoking and the range was between 2-3% on all of them! this motor seems to be healthy. but i know theres gotta be something.
avotegra
Dec 13, 2009 11:45 PM
soon2bdropped
Jun 9, 2007 02:13 PM
huge230
Dec 18, 2006 07:29 AM
eg2wes
Dec 25, 2005 05:11 PM
Sleek98
10
Sep 19, 2003 10:58 PM
