NEW engine, new problem
Old May 12, 2004 | 09:55 PM
murmur9's Avatar
Default NEW engine, new problem
I just did a swap with the same engine as my old one, on a honda civic 1997 ex
I got the head and everything together, runs perfect....i push in the break put it in reverse.....nothing. go to drive, same thing. this is an auto, not a manual. What could i have done wrong?
Old May 12, 2004 | 09:58 PM
jameskersten1's Avatar
Default Re: NEW engine, new problem (murmur9)
is everything hooked up? there is a cable i believe the runs form your shifter to your tranny, is it hooked up? second could be a sensor this is unhooked or not wokring. someone else might know better then me. just some ideas
Old May 12, 2004 | 10:01 PM
triggerX's Avatar
I've done that swap a few times. Make sure the shifter cable is properly reinstalled back into its location in the tranny.
Old May 12, 2004 | 10:02 PM
murmur9's Avatar
Default Re: NEW engine, new problem (jameskersten1)
yea, the shift cable, i never disconnected it from the tranny and im usin the same old one, i just disconnected it from the shifter that is ran into the car.
Old May 12, 2004 | 10:03 PM
murmur9's Avatar
what if i never took it out of the tranny, i unbolted it from the underside where it runs into the inside of the car to the shifter,
si1992
May 18, 2012 04:27 AM
h22lude317
Feb 1, 2009 04:47 PM
honey mead
Aug 13, 2006 03:56 PM
Arch-Angel
Apr 13, 2005 01:32 PM
daver
Sep 8, 2004 11:24 PM
