questions about 4 point seatbelt harness install
Old May 12, 2004 | 08:19 PM
teggytegteg's Avatar
Default questions about 4 point seatbelt harness install
sup ya'll.i have a DA9 and i was wondering if theres anyway of installing the 4 point seat harness without welding or drilling. can you guys tell me if there are holes that i can put the three bolts into. thnx guys
Old May 12, 2004 | 08:23 PM
Kendall's Avatar
Unless you are using a roll bar or roll cage, then a 4 point harness will do more harm than good. I suggest not installing them until you can install them properly.
Old May 12, 2004 | 08:26 PM
martinez32's Avatar
Default Re: questions about 4 point seatbelt harness install (teggytegteg)
I've seen people bolt it in the rear seat belt latch, but personally i would do the Sparco Harness bar if you don't use your back seat alot
http://www.sparcousa.com/harness_bars.asp
safest way to do it unless u go full roll cage
Old May 12, 2004 | 08:27 PM
xSCTYGx's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Unless you are using a roll bar or roll cage, then a 4 point harness will do more harm than good. I suggest not installing them until you can install them properly.</TD></TR></TABLE>
Correct, either way without drilling I dont think there is anyplace to mount it...Stick with Kendall's advice
Old May 12, 2004 | 08:59 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: questions about 4 point seatbelt harness install (martinez32)
There is no "safe" way to do it if there is no rollover protection, ESPECIALLY if you use them on the street. Nothing is more unpredictable than street driving, somebody can come out of nowhere and hit you and make your car flip over, most likely killing you if you're using harnesses w/ rollover protection. Take my dad for example, last Father's Day he was on the highway and a car came bounding across the median, spun around, and my dad's truck slammed the car's left fender at 60+ mph. There was no warning, and nothing he could have done to avoid it (street were wet, too, after a recent rain).
On top of that, 4-point harnesses aren't that great anyway, I don't think any 4-point setups are FIA approved (correct me if I'm wrong) but 5 or 6-point belts are much safer as the 5th and 6th straps keep the lap belts in place and keep you from going underneath it.
Old May 13, 2004 | 02:27 AM
d8168055's Avatar
Default Re: questions about 4 point seatbelt harness install (PatrickGSR94)
i use a "psuedo" 4-pt harness for autox made by scroth and it works well... The rally 3 connects in 1 pt in the rear (i used the c-pillar) where the rally 4 uses 2 (can use ur stock seat best positions). U can easily disconnect them when not in use, and still be able to use ur rear seats...
I would never wear it on the streets however, simply it is impractical and dangerous... when reversing, u cant turn ur torso to look back, nor can u reach ur glove compartment if u needed to...
meheartmycivic
Sep 2, 2009 09:46 PM
EusebioSam19
Aug 20, 2009 02:01 PM
eskimo_usd
Sep 9, 2005 08:41 AM
pearlws
Honda S2000
Feb 2, 2004 03:36 PM
