Need LSvtec advice!
Old May 12, 2004 | 07:42 PM
kaptr1d's Avatar
Default Need LSvtec advice!
ok. so i had intended to build my b16 to a mild degree and then be done. however, when i had asked questions about upgrading to ctr pistons to make the most out of my skunk2 stage2 cams many asked why i was wasting my time/money on a 1.6 when i would have much more potential to deal with out of a 1.8-2.0
so i have aquired a b18a from a 91 integra gs. it has approx 60k miles on it. The head of my b16 is mildly built. I was list what I already have and what I know or think I should order on top of this. Plz advize me on what parts i need to add or should drop.
JDM b16 head - aebs i/m, hondata i/m gasket, skunk2 stage2 cams, skunk2 springs/retainers, new cam seal, new dizzy, aem fpr and fuel rail, venom fuel pump.
accesories - obx 4-2-1 header, 2.5" test pipe, full 2.5" exhaust, dc sports intake, generic wires and plugs.
ordering - golden eagle vtec kit (http://www.groupbuycenter.com/buy.aspx?id=15311), usdm itr pistons/rings (http://www.inlinefour.com/usspecintypp.html), arp head studs and rod bolts.
some ppl have said that aftermarket rods are a must? i dont beat on my motors, but it will see some street time.
Thanks for all ur advice.
Old May 13, 2004 | 03:05 PM
kaptr1d's Avatar
bump.
Old May 13, 2004 | 03:58 PM
hotintegranights's Avatar
Default Re: (kaptr1d)
who ever told you aftermarket rods are a must has to be trying to sell you their rods. all you need is $40 arp rod bolts and your good to go, and if you want to rev it to 9rpm then shot peen would not be a bad idea but its not a must.
also put this on top of your list as is def a must.
ITR/GSR oil/water pump
Old May 13, 2004 | 04:19 PM
nickgmiller04's Avatar
Default Re: (hotintegranights)
i agree about the water/oil pumps. if you have the extra cash then get rods and pistons because i dont think stock pistons go on forged rods w/o a machince shop. ive been looking at probe rods for my future engine. id shotpeen them at the very least tho. but thats me. you dont HAVE to, but it be safer and stronger if you did.
my engine is still stock. so what do i know??
hey, howd you get a 91 b18 w/ only 60k??? good find. thats way low mileage
and make sure you replace every seal and bearing on the engine. so it be like a new engine.
Old May 13, 2004 | 07:48 PM
Combustion Contraption's Avatar
i have a little over 1500 miles on my ls/vtec swap and its running great. i know i havent been running it long enough to dispel all the myths, but i did pretty much what everyone on this thread has said so far. all new bearings and seals, vtec oil and water pumps, and stock LS rods shot peened with ARP rod bolts.
Old May 13, 2004 | 10:37 PM
VtecDA9's Avatar
Default Re: Need LSvtec advice! (kaptr1d)
you'll be good to go with my setup and similar as far as the machining, balancing, clearances, and right bearing sizes etc... https://honda-tech.com/zerothread?id=861207
Old May 14, 2004 | 10:52 AM
crxracer2's Avatar
hey how much r u spendin on the arp stuff cuz i waz on the prostreetonline.com site and they r sellin there arp head studs for only 67.99 but how much r u payin at ur spot?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaptr1d &raquo;</TD></TR><TR><TD CLASS="quote">ok. so i had intended to build my b16 to a mild degree and then be done. however, when i had asked questions about upgrading to ctr pistons to make the most out of my skunk2 stage2 cams many asked why i was wasting my time/money on a 1.6 when i would have much more potential to deal with out of a 1.8-2.0
</TD></TR></TABLE> man how much r u payin for those arp head studs cuz at prostreetonline.com they r sellin for 67.99
Old May 14, 2004 | 01:13 PM
kaptr1d's Avatar
ok. so i found some parts.
gsr rods/with jdm itr pistons, gsr oil pump/water pump, gsr timing belt.
also there is a good machine shop nearby me to balance the rotating assembly/assemble the block/head combo etc.
should i buy the oem stuff direct from honda or are other places cheaper,
do i need to shot peen the gsr rods or are they good to go,
any issues with this setup, fe. will the gsr rods fit ok,
thanks.
Old May 14, 2004 | 01:32 PM
crxirex's Avatar
if you have a b16 do this.
https://honda-tech.com/zerothread?id=815614
It will give you less problems, it will look like a 1.6. An you will be fast. Plus its cheaper then building a new motor .
Old May 14, 2004 | 02:17 PM
kaptr1d's Avatar
Default Re: (crxirex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxirex &raquo;</TD></TR><TR><TD CLASS="quote">It will give you less problems, it will look like a 1.6. An you will be fast. Plus its cheaper then building a new motor</TD></TR></TABLE>
a- why would it give me less problem? itd be swapping parts on a b16 block and changing bore to make it an ls block. im swapping parts to make a b18 block like a b16 block, already has the bore (well stroke really).
b- i dont think thats a less expensive option for me. not even close really.
Ive read and re-read that whole thread prior to this, and i dont really see it workin for me.
Old May 14, 2004 | 02:40 PM
Mr_CRX's Avatar
Default Re: Need LSvtec advice! (crxracer2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxracer2 &raquo;</TD></TR><TR><TD CLASS="quote">man how much r u payin for those arp head studs cuz at prostreetonline.com they r sellin for 67.99 </TD></TR></TABLE>
did you actually click on the "Applications" link?
Unless you have a Chevy or Mopar, you arent getting them for $68 from that site..
Old May 14, 2004 | 03:07 PM
Default Re: Need LSvtec advice! (Mr_CRX)
use the ls rods, sell the gsr rods
Old May 14, 2004 | 03:12 PM
crxirex's Avatar
A - The motor only cost 2grand
B - The head and lock were ment to be on one another, no predrilling ****, nothing extra needed.
C - All it is, is a 81.5 bore, ls crank/rods, in a 1.6 block.
If thats more work, then you think your doing now you have some issue's.
An mostly I highly doubt your only spending 2 grand ona fully blue printed monster like that one that he sell's. You obviously didn't read it enough.
Old May 14, 2004 | 05:22 PM
kaptr1d's Avatar
i already have a b16 and a b18... but after rereading the tech43 post im thinkin about gettin the 81.5mm stroker kit.
it would give me the exact compression that im told my skunk2 cams like and i wouldnt have to worry about changin the oil/water pumps, timing belt, bearings, etc.
ill just take out the ls crank and rods and get them shot peened...
sounds good to me, what do yall think?
Old May 15, 2004 | 09:56 AM
crxirex's Avatar
haha, I think your learning
DC2-ProdUcTiOnS
14
Mar 15, 2009 03:43 PM
DC2-ProdUcTiOnS
Mar 13, 2009 04:32 PM
viet_boi_racin
Apr 25, 2007 09:46 AM
b16powwer
28
Oct 17, 2004 10:35 PM
