Speaker problem
Guest
Posts: n/a
I own a 93 del sol SI. I recently purchased 6x9" Alpine type R speakers for the rear of it. Problem is 6 1\2" speakers are what go in the back and some gay bracket. I was wondering if there is any brackets out that would let the 6x9" fit in the back.
Hey 6X9's won't fit in the rear. The doors and the rear is 6in speakers in them. I have 2 sets of Boston Acoustics RX67's in my del sol and I had a problem installing them in the rear. The problem I had was with the corners in the rear, I didn't have enough space because the magnets were too big and the magnets were sticking to the metal and would not fit. So when I installed the speakers in the doors the magnets were to big to fit in the basket so I just took the baskets out and they fit fine. So I took my dremel tool and cut off the rear part from the baskets and just kept the ring where you put the screws in. I used the rings as a spacer for the rear speakers and the speakers fit perfectly. You just have to drill the holes in the spacer you made to match up the holes on the metal ring where you have to mount the speakers in the back. Hope this wasn't confusing, I tried to explain it the best way I could. So just consider magnet size when buying speakers for the rear.
s2000onvolks
10
Feb 1, 2008 08:33 AM
s2000onvolks
Audio / Security / Video
Jan 31, 2008 04:19 PM
deadlock32
Feb 28, 2006 01:12 PM
