Clutch system working pressure
Old May 12, 2004 | 11:29 AM
Andy M's Avatar
Default Clutch system working pressure
Do any of you know what the working pressure is in a hydraulic clutch system is? Perhaps one of you has measured the pressure in the line near the slave, or knows how to compute the working pressure as a function of the weight of the pressure plate. If you have any insight, I'd appreciate it greatly.
If nobody knows, I'll put a brake pressure guage on a H-series clutch system and measure it, and post my findings.
Thanks!
Old May 12, 2004 | 02:26 PM
VtechHatch!'s Avatar
Default Re: Clutch system working pressure (jazzman)
bump
Old May 12, 2004 | 02:53 PM
Ekasey's Avatar
Default Re: Clutch system working pressure (VtechHatch!)
there is a mathematicla formula but you need the orifice size the piston size and the stroke length. probably easier to sue a brake pressure gauge tapped in
Old May 13, 2004 | 08:43 AM
Andy M's Avatar
Default Re: Clutch system working pressure (eLusive ek4)
I'm probably going to use a brake pressure guage, but I'll give this thread one more bump, just in case!
Old May 13, 2004 | 10:34 AM
JimBlake's Avatar
(Pedal force X pedal mechanical advantage) / (MC piston area)
No orifice sizes or stroke length or anything like that is involved... You can measure the distances between the pedal, piston clevis, & pivot point to get the mechanical advantage. I don't know what the MC bore is, & I'm not sure how you would reliably measure the pedal force.
So it might be easier to use a pressure gauge.
edit...
If I wanted to take a WILD guess;
force = 10 lbf
M.A. = 4
bore = 1/2"
(10 X 4) / (pi/4 * 0.5^2) = around 200 psi
scoker83
16
May 12, 2014 07:01 PM
JDM_SOHC
36
May 21, 2007 03:50 PM
beefjerky
Jun 6, 2006 09:18 PM
Kp_VtekNiks
10
Dec 1, 2004 05:15 PM
thehatchninja
10
Mar 25, 2004 02:03 PM
