blown rings need some opinions here
ok my rings are dead.....i am going to rebuild the motor with an aftermarket piston and either aftermarket rods or shotpeened stock ones.....which compnayies would you recomend and why? do u have any experience with them? if so good or bad///
ok thanks
ok thanks
Or go with Eagle rods. I saw them at SEMA and they are very good quality. Plus, they are cheaper than crower. If Im not mistaken JoJo Callos is running eagle rods now.
art
art
ok now how about a compression level.....keep in mind i have a b16 head on a gsr bottom (basicly yeilds 9.8-1 or like basicly like an itr motor with out the compression level )
i know a place that can get you eagle rods shipped to your door for $325.
email me immy@Home.com if you are interested.
id go with pauter rods and je pistons... and to everyone who says quality is the same... ill get pictures of the differances between pauter rods and crowers at least and yest there are diffferances... and i even know of crower's snapping fyi
White= coolant
Blue= oil
Black= gas (rich)
It's hard to tell sometimes between white and blue.. but if you see any tint of blue to the smoke, you are burning oil. That can be caused by blown rings or bad valve seals.
[Modified by Rob92SC, 5:28 PM 11/6/2001]
Blue= oil
Black= gas (rich)
it depends on which rings are blown. If you blow compression rings (like I did) you will experience less compression which equals less power. Blown oil rings will just let alot of oil into the combustion chamber, which can coat the chamber causing less combustion efficiency. If you have blown rings, better take the engine apart and do a rebuild.
yah i had just installed the kit when i bought my setup i bought it used from a friend of mine and he forgot to enclose the fitting for the back of the wastegate and never said i needed one........so i was running infinate boost and well the story just ends it self right there.......anyway what i can say is that i have learned a lot from this horrible experience....but yah know what its also just a good excuse to rebuild my block to be stronger than stock lol
