D16Z6 help>>>I searched already>>>>
I have <U>160k</U> on my motor and I want to rebuild but I dont know how much stress has been put on the block........So How do I determine if the block is worth building... The engine has had regular maintanance with the only problem being it overheating from a bad radiator...... I've heard to check with a straight edge and a feeler guage for warpage but I believe its the head.........All comments welcomed..........
a D-series motor isnt really worth rebuilding, because you can probably find yourself another engine (JDM D15B, D16Z6/Y8) w/ less mileage and less wear/tear for cheaper than rebuilding your Z6.
I'll agree to a point with illuzionz - if you are going back stock, find a replacement. It will probably be cheaper - and a rebuild isn't going to be as good as Honda's first build anyway.
If you are going to do a "build" like with aftermarket rods/pistons, let a machine shop check it for you - just make sure it's a reputable place and give them the specs from a Helms manual on warpage etc.
My $.02
My $.02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">a D-series motor isnt really worth rebuilding, because you can probably find yourself another engine (JDM D15B, D16Z6/Y8) w/ less mileage and less wear/tear for cheaper than rebuilding your Z6.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicminded92 »</TD></TR><TR><TD CLASS="quote">I'll agree to a point with illuzionz - if you are going back stock, find a replacement. It will probably be cheaper - and a rebuild isn't going to be as good as Honda's first build anyway.
My $.02</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Simple...just do a compression test.</TD></TR></TABLE>
leakdown tests own compression tests.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
leakdown tests own compression tests.</TD></TR></TABLE>
mullet hunting owns nissans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">mullet hunting owns nissans.</TD></TR></TABLE>
dude once again, dont you have like something better to do rather than try to make fun of my superior skyline engine?
go defend our country *****!
haha. Why would I need to try? Don't make me put a jet engine in my civic.
</TD></TR></TABLE>haha. Why would I need to try? Don't make me put a jet engine in my civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">haha. Why would I need to try? Don't make me put a jet engine in my civic.
you dont have the *****.
</TD></TR></TABLE>you dont have the *****.
allricedout
50
May 31, 2007 10:27 AM
