CRX wheel space problem....
ok i have 15" rota slip streams ... 6.5 wide... with falken azinis on it... and my car is lowered with tein superstreets...
my wheel has a bad camber problem... 3. somthing degree's off and if i try to strighten it with a camber kit... the wheel is going to bottom out on the top of the fender in the wheel well.... if you know what i mean...
anyone run into this same problem? if so how did you fix it?
thanks buddy real help there....
and rolling the fender isn't the problem.. it hits the TOP outside of the wheel well... and how high should i go? 4" lift? get real buddy i'm not scrapeing the ground... i have about a haft inch from the top of the tire to the fender. and camber kit will pull the top out... i need the bottom pushed in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleep »</TD></TR><TR><TD CLASS="quote">...and camber kit will pull the top out... i need the bottom pushed in.</TD></TR></TABLE>
SPC part # 69200
Will pull the bottom of the wheel in as opposed to pushing the top out...It can be had for just over $200.
SPC part # 69200
your tire is hitting the TOP!!!!! of the ******* inner wheel well and you dont think youre car is lowered to much? Mines lowerred 2.5" also on 50 series azenis and 15" slips and I have a finger gap, you must be dropped 5"
