is 400cc too big for lsvtec?
Old May 11, 2004 | 09:34 PM
my ride's Avatar
Default is 400cc too big for lsvtec?
im running a lsvtec will itr piston and toda b cams and thinking about getting injectors. is 400cc too big? and what will happen if i put them on? i know 310cc is good enough, but i got a good deal on some 400s. any help will be geart.
Old May 11, 2004 | 09:39 PM
zad5's Avatar
if you get the car tuned with hondata nothing should happen it should work. but some would feel its overkill but it shouldnt matter.
Old May 11, 2004 | 09:47 PM
TEAMGENDAI's Avatar
Default Re: (zad5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zad5 &raquo;</TD></TR><TR><TD CLASS="quote">if you get the car tuned with hondata nothing should happen it should work. but some would feel its overkill but it shouldnt matter.</TD></TR></TABLE> EXACTLY
Old May 11, 2004 | 10:30 PM
T.J.'s Avatar
Default Re: is 400cc too big for lsvtec? (my ride)
as long as you have proper tunning, you wont have any problem.
Old May 12, 2004 | 06:47 AM
b19coupe's Avatar
If you run 440 cc injectors on a stock ECU or a generic chipped ECU, the car will barely run. With Hondata or other programmable engine management, you will be fine.
2k.civic.si
May 17, 2006 09:20 AM
BI8B
Jan 6, 2005 05:33 AM
Nextelbuddy
Jul 4, 2004 03:28 PM
B18C1_T
Oct 26, 2003 06:40 AM
madman604
Feb 11, 2003 09:45 AM
