missing nuts and bolts
Ok I just checked on which nuts and bolts are missing on my motor mounts I narrowed them down and Im currently in the process of going through my Helms to see if I can find out the exact specs of the pieces im missing. Now my question is should I just go to home depot and get the highest quality nuts and bolts that im missing or should I just go to acura so I can get raped by their probably rediculous bolts, if they even have them.
Anyway if your lookign right at the engine, on the:
Right motor mount - need the new nuts that screw in on top
Rear mount - bolt and nut that goes through the middle of the mount
tranny mount - 2 nuts on the top
lower tranny mount - 2 bolts that go into the frame and the same with the lower right mount.
So should I HD it or acura it
hit up len - he sells ac parts in the sponsors"performance" section - dirt cheap
also http://www.acuraautomotiveparts.org/ - for part #s
yea only problem is im looking to do this tomorrow so I can get it mounted before my classes start next week again. Anyway
ie - the helms says for one of the nuts and bolts that im missing on the right engine mount -
10 x 1.25 mm
52 N m (5.3kgf m, 38 lb-ft)
So I guess the 52 N m is just how tight to torque it down(38 lb ft) And if I took the book with the dimensions of 10 x1.25 would the guys at HD be able to find the correc nuts and bolts?
10 x 1.25 mm
yea they prolly have em but you better make sure theyre good grade bolts - the 10x1.25mm is the size - you should check the price against the acura price - it would be worth it to me to spend a couple bucks extra
civicsiguy21
Apr 15, 2014 03:08 AM
webbs2jzgte
Jan 12, 2010 06:04 PM
