missing nuts and bolts
Old May 11, 2004 | 08:45 PM
LostAndFound's Avatar
Default missing nuts and bolts
Ok I just checked on which nuts and bolts are missing on my motor mounts I narrowed them down and Im currently in the process of going through my Helms to see if I can find out the exact specs of the pieces im missing. Now my question is should I just go to home depot and get the highest quality nuts and bolts that im missing or should I just go to acura so I can get raped by their probably rediculous bolts, if they even have them.
Anyway if your lookign right at the engine, on the:
Right motor mount - need the new nuts that screw in on top
Rear mount - bolt and nut that goes through the middle of the mount
tranny mount - 2 nuts on the top
lower tranny mount - 2 bolts that go into the frame and the same with the lower right mount.
So should I HD it or acura it
Old May 11, 2004 | 08:50 PM
frenchy's Avatar
Default Re: missing nuts and bolts (LostAndFound)
hit up len - he sells ac parts in the sponsors"performance" section - dirt cheap
also http://www.acuraautomotiveparts.org/ - for part #s
Old May 11, 2004 | 08:53 PM
yea only problem is im looking to do this tomorrow so I can get it mounted before my classes start next week again. Anyway
ie - the helms says for one of the nuts and bolts that im missing on the right engine mount -
10 x 1.25 mm
52 N m (5.3kgf m, 38 lb-ft)
So I guess the 52 N m is just how tight to torque it down(38 lb ft) And if I took the book with the dimensions of 10 x1.25 would the guys at HD be able to find the correc nuts and bolts?
Old May 11, 2004 | 09:20 PM
frenchy's Avatar
Default Re: (LostAndFound)
yea they prolly have em but you better make sure theyre good grade bolts - the 10x1.25mm is the size - you should check the price against the acura price - it would be worth it to me to spend a couple bucks extra
Old May 11, 2004 | 09:24 PM
frenchy's Avatar
Default Re: (frenchy)
you can find out what the list price on the hardware you need on the prevoiusly posted site, and compare them with the hardware store prices
civicsiguy21
Apr 15, 2014 03:08 AM
webbs2jzgte
Jan 12, 2010 06:04 PM
iceman24
16
Apr 6, 2005 06:02 PM
herde1724
Feb 27, 2004 07:36 AM
