I spliced my 02 wires, now the car is hesitating
Old May 11, 2004 | 08:25 PM
yusoslo's Avatar
Default I spliced my 02 wires, now the car is hesitating
I need to lengthen the wires to fit my downpipe on the turbo install and now my car stutters and almost acts like there is no throttle when I barely get on it from 2500 - 3000 after that its fine.
I heard you need sheilded wired for the 02 sensor, plus I do not have vtec hooked up at the moment
btw this is a d16z6
thanks for any help
Old May 12, 2004 | 06:04 AM
yusoslo's Avatar
Default Re: I spliced my 02 wires, now the car is hesitating (yusoslo)
up
Old May 12, 2004 | 09:31 AM
yusoslo's Avatar
anyone
Old May 12, 2004 | 02:34 PM
yusoslo's Avatar
h,mmmm
Old May 12, 2004 | 02:35 PM
poison's Avatar
You sure you didn't cross any wires?
I'd verify with a digital multimeter.
Are you throwing the O2 code now?
Old May 12, 2004 | 02:46 PM
Ekasey's Avatar
Default Re: I spliced my 02 wires, now the car is hesitating (poison)
how did you splice the o2 wires did you solder the wires, you might have developed a high recistance situation. Which will send faulty reading to the ecu recistance check the wires you splice by isolating them from the rest of the circuit
Old May 13, 2004 | 03:16 PM
yusoslo's Avatar
Default Re: I spliced my 02 wires, now the car is hesitating (eLusive ek4)
well I did not solder them, I used some cheap single strand radio shack wire to lengthen it about 3 more feet. Yes there is more resistance, but now I thing i should have extended the harness not the 02 sensor
Old May 13, 2004 | 03:35 PM
Ekasey's Avatar
single strandswire is your first mistake you need to use multi strand wire in the same gauge as the factory
Old May 16, 2004 | 10:30 AM
yusoslo's Avatar
other than that will shielded wire benifit me? the singe wire is the same gauge, i didnt find this out untill I got home from radio shack
Old May 17, 2004 | 07:00 AM
Ekasey's Avatar
shielded wire is not necessary just mulitstrand copper rubber insulated will be fine in the same gauge desired
blindsk8er1013
Sep 16, 2008 04:38 PM
Achenar
12
Dec 30, 2005 09:17 PM
94si94cx
Apr 30, 2003 03:59 PM
