how can i tell if my ecu is jdm?
Old May 11, 2004 | 08:14 PM
hb_racer's Avatar
Default how can i tell if my ecu is jdm?
I have a p28 ecu. I'm guessing that because on my ecu it says "37820-P28-L01" So i'm assuming p28. Now, i have a b16a sirII and it came with a different ecu and got this one from a friend. I sold the other one and stayed with this one. My real concern is, if it is a usdm, will it matter? If not, cool. If so, I need to get a jdm one.
thanks
Old May 11, 2004 | 08:25 PM
Jim Truett's Avatar
Default Re: how can i tell if my ecu is jdm? (hb_racer)
From that # I can tell you have a USDM P28 ECU for California Emissions. It was also made in late 1992 or 1993.
Why do you need a JDM ECU anyway?
Old May 11, 2004 | 08:46 PM
hb_racer's Avatar
Default Re: how can i tell if my ecu is jdm? (Jim Truett)
thanks for the reply... If it is USDM, then does it matter? I read some topics somewhere about jdm vs. usdm and that somethings might not work right. The car seems to drive okay, but it doesn't feel fast as it should. But that doesn't mean much. anyways, thanks. Anyone know if it matters?
Old May 11, 2004 | 08:52 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb_racer &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the reply... If it is USDM, then does it matter? I read some topics somewhere about jdm vs. usdm and that somethings might not work right. The car seems to drive okay, but it doesn't feel fast as it should. But that doesn't mean much. anyways, thanks. Anyone know if it matters?</TD></TR></TABLE>
You are running a B16 with a stock P28. The fuel and timing maps are way off. Get the P28 chipped properly or find a P30 ECU. http://www.pgmfi.org
Old May 11, 2004 | 09:29 PM
hb_racer's Avatar
the ecu is chipped. Mugen chipped. but i don't know if it for the b16. how can i tell? do i need to open up the ecu?
Thanks
Old May 11, 2004 | 10:28 PM
hb_racer's Avatar
I opened it up. There is a sticker in there on a chip that says, " 20020409MG" Then beneaht that it says that it has a 9500 rpm and 5700 vtec. So would this be okay for my motor?
thanks
Old May 12, 2004 | 12:53 AM
Nerologic's Avatar
Old May 12, 2004 | 04:46 AM
PokeyD16Z's Avatar
Default Re: how can i tell if my ecu is jdm? (Nerologic)
I've got a Euro P28 in my car.
Old May 12, 2004 | 05:48 AM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb_racer &raquo;</TD></TR><TR><TD CLASS="quote">I opened it up. There is a sticker in there on a chip that says, " 20020409MG" Then beneaht that it says that it has a 9500 rpm and 5700 vtec. So would this be okay for my motor?
thanks</TD></TR></TABLE>
I bet you are running way too rich.
Old May 12, 2004 | 09:22 AM
hb_racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
I bet you are running way too rich.</TD></TR></TABLE>
How can I tell if I'm running too rich? and what gives you that impression?
thanks
Old May 12, 2004 | 10:18 AM
Jim Truett's Avatar
Smell your exhaust and look for black soot on your rear bumper. I have seen the MUGEN fuel and timing maps. Research the program you have on http://www.pgmfi.org
Old May 12, 2004 | 01:19 PM
hb_racer's Avatar
thanks, i'll check it that way. I went to that site and I don't really understand what is going on. If i am running rich... all i could really do is go for a tune right?
thanks
Old May 12, 2004 | 09:27 PM
letmeseeyouskip's Avatar
If your plugs:
Black - your car is running rich.
White - your car is running lean.
Tan or light gray - your car is running perfectly.
* Some people like to run a little rich than other. It is a personal choice.
Well i know you guys are talking about OBD-I but for the image that the JDM ECU is smaller than USDM does not go for OBD-II the 2000-2001 ECU's right?
Old May 13, 2004 | 08:54 AM
fastontheturns's Avatar
i have a obd pr3 ecu is that good ? any weak points ?
NaCk3m
Sep 7, 2006 05:52 PM
shyxboy
10
Apr 20, 2006 04:39 PM
Lauj87
Oct 16, 2005 10:27 AM
Fatty_1775
Aug 22, 2005 06:30 AM
winman517
Mar 9, 2005 08:24 PM
