Draft:Help I looked... Stainless brake lines???
Hello everyone. I have a 92 Civic Si, and i got a set of front ex 2 door front brakes.
(the 10.2 inch models)I was wondering what stainless steel brake lines i should purchase from experience...Any that have a plastic protective coating?
Thanks,
Stephen
Thanks,
Stephen
For the Ex would be fine. Just make sure as long as you still have the rear drums, that the set is for a front disk/ drum rear setup.
Okay, basically what I am telling you, is that if you have 4 disks, you can use the lines from any car with 4 disks (ex, Integra, 99-00 SI, etc.). If you have disks up front and drums out back, you can use the lines for any car with that setup.
blu3g
May 21, 2007 09:24 AM
Ajax
Aug 15, 2004 06:38 AM
