Brake Hose Routing
Brake Hose Routing
I just wanted to see how yall routed your brake hoses. These are Goodridge Stainless Steel brake lines for a 99-00 SI. I have a rear disc conversion from a 92 Integra on my 97 HX, so I figured this would be the correct set. But when I jack up the rear of the car, the brake lines get a little tighter than I would like. I was thinking about grinding down the caliper so I could turn the bend the other way. Just wanted yall's opinion before I did anything. Sorry for the big pics.
* B A N N E D *
1 Post
Re: Brake Hose Routing (Luserkid)
With my stainless lines, they didnt fit perfectly either. But I ran the banjo side of the line through those two tabs, and its 180% of how you have it (other side of the round connector. Also, I ran mine around the shock. If the line is stubborn, take a regular open end wrench and turn the part of the hose where it goes to the car's hardline and the whole line rotates sort of.
redboost10
Suspension & Brakes
10-30-2008 08:55 AM
neoboi
07-07-2003 07:57 AM
