New CTC Gearset Larger Dog design
Old May 11, 2004 | 03:00 PM
JasonCTC's Avatar
Default New CTC Gearset Larger Dog design
Just some new info for the hardcore racers out there that keep breaking stock gears or other gearsets. Here is a picture of our newly designed gear set with larger dogrings. There should not be any problems with these dogrings!!! Only problem we had with the gears was the previous model 3-4 slider dogring eventually wore out. Yes dogrings will have to be replaced every season on the serious drag cars. (Low 8 to low 9 sec Pro 4 cyl type cars). On high 9 second to 10 second cars they should last 2 years and all motor should last even longer before maintanance. Replacement dogrings and gears are about $250-400 each depending on which ones. Custom ratios available. Those racers with Motecs, send us some ratios you want. Use those expensive computers to your advantage and get an edge over the other guys. Who better to know what you need than you and your crew? With a strengthend or cable bellhousing I see no problems in reliability. Have to make sure the shafts don't try to push apart and crack the bearing area on the bellhousing. A cable bellhousing with a Tilton TOB or something like that would be ideal or we can reinforce your hydraulic bellhousing. We should have an upper support plate to help keep the shafts together sometime soon as well.
http://store5.yimg.com/I/shopctc_1793_11700592
http://www.ctcmotorsports.com
http://www.wasabiracing.com
Old May 11, 2004 | 03:13 PM
Jokerluv's Avatar
Default Re: New CTC Gearset Larger Dog design (JasonCTC)
wasabi racing
Old May 11, 2004 | 06:07 PM
badCRX's Avatar
New User
Default Re: New CTC Gearset Larger Dog design (Jokerluv)
so is this for the cable trannies like the J1 and S1, or for the YS1?
Old May 11, 2004 | 08:02 PM
tony1's Avatar
Default Re: New CTC Gearset Larger Dog design (badCRX)
These guys are legit, it's an awesome gearset. I know first hand...
Old May 11, 2004 | 08:10 PM
Kataku2K3's Avatar
Default Re: New CTC Gearset Larger Dog design (tony1)
Badass looking stuff
Old May 11, 2004 | 08:13 PM
six sigma racing's Avatar
Default Re: New CTC Gearset Larger Dog design (Kataku2K3)
well now i will officially start saving my money...
Old May 12, 2004 | 11:41 AM
Gearspeed-Performance's Avatar
Default Re: New CTC Gearset Larger Dog design (DTRFAB)
Quality product!!
Hope to get a set from you guys soon
Old May 12, 2004 | 12:18 PM
Boostin'RPS13's Avatar
Default Re: New CTC Gearset Larger Dog design (GearSpeedEF9)
very cool.
Throwdown
Apr 3, 2018 08:05 AM
gogetta
Jun 25, 2011 05:00 PM
cjordan
Apr 12, 2010 06:24 PM
ComeOnKip
Jan 17, 2008 08:19 AM
Bense
Welding / Fabrication
16
Oct 26, 2006 04:38 AM
