what map sensor do i use?? one on firewall or one with motor?
Old May 11, 2004 | 12:06 PM
coot_er's Avatar
Default what map sensor do i use?? one on firewall or one with motor?
when i got my engine it came with a map sensor connected to it. do i use that one or the one on my firewall. these vacuum lines are a pain to figure out!
i have a 91 Hf with a b16a1
Old May 11, 2004 | 12:27 PM
96-EJ6 B18C's Avatar
Default Re: what map sensor do i use?? one on firewall or one with motor? (coot_er)
I personally run the OBDI MAP on my car. If you have one connected to the throttle body then just use that one and you don't have to run the vac line to it. Then you can remove that ugly *** pos from the firewall.
Old May 11, 2004 | 01:00 PM
coot_er's Avatar
Default Re: what map sensor do i use?? one on firewall or one with motor? (96-EJ6 B18C)
can i remove everything from the firewall or just the map?
Old May 11, 2004 | 01:58 PM
coot_er's Avatar
its connected to the trottle body by a vacuum tube, its not directly on in. so can i remove everything inside that black box on the fire wall. how do i run the vacuum tubes?
Old May 11, 2004 | 05:16 PM
0554's Avatar
i donno man i used the map sensor on the tb and my car rac slower than with the firewall map. i have no clue why it idled fine and drove fine but just didnt have the throttle response
Old May 11, 2004 | 05:33 PM
Default Re: (88crex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crex &raquo;</TD></TR><TR><TD CLASS="quote">i donno man i used the map sensor on the tb and my car rac slower than with the firewall map. i have no clue why it idled fine and drove fine but just didnt have the throttle response </TD></TR></TABLE>
I would have to say that something was wrong with the sensor...My car runs fine on either sensor and I can't even tell the difference as to which one I have hooked up.
Old May 11, 2004 | 08:32 PM
0554's Avatar
yea i donno something wasnt right.
david22ky
19
Aug 21, 2007 08:11 PM
Pooper
Oct 16, 2006 09:19 PM
ALL MOTOR DA
Jun 8, 2006 02:35 PM
92eg6_pino
Jan 7, 2006 05:33 PM
88 rex
Aug 4, 2005 04:58 PM
