Alternator wiring
Old May 11, 2004 | 08:26 AM
Steve91's Avatar
Default Alternator wiring
No luck searching, so I'm trying here.
Is there anyway to run the Honda alternators without the factory ECU? I'm working one two cars. One is a 1991 CRX that will have dual carbs. I want to remove all the EFI wiring and the ECU. Its a race car, so I don't need any ECU functions. If I hook the output wire from the alt to the fuse box, will the alt charge the battery, or will I have to activate the alternator somehow with one of the other wires?
The second car is the same setup but will be running Electromotive EFI.
Thanks
Old May 11, 2004 | 11:00 AM
RedZone's Avatar
Default Re: Alternator wiring (Steve91)
yes you can run the altinator without the ecu, just hook up the power wire from the altinator 4 wire plug, which should be the black/yellow to a switch for power so you can turn it on and off from a the battery source so it will not drian the battery. Im still at home right now but i will be heading to the shop and i will verify the color of the wire jsut incase.
Old May 11, 2004 | 11:01 AM
Steve91's Avatar
Default Re: Alternator wiring (RedZone)
Thanks for the info.
Old May 11, 2004 | 03:19 PM
RedZone's Avatar
Just to let you know I double checked and I was right on the wire color......have fun with the duel carbs.....we did that setup back in 2000 with NOS and it ran great. 11.00@121 with only 190whp to the wheel on a stock spec gsr and then we put 120 shot direct on top.
arthur8
Feb 6, 2018 05:46 AM
pr0honda
Oct 21, 2009 09:22 AM
kuja
Sep 1, 2005 09:52 PM
jonoknut
Sep 19, 2002 03:17 PM
