please help! ticking under load from d16z6
Old May 11, 2004 | 07:59 AM
serious's Avatar
Default please help! ticking under load from d16z6
d16z6
ticking under load, starting around 2800 rpm. mechanic has been unable to locate noise. the ticking is quiet, and has been doing it unchanged for nearly a 1000 miles now. the ticking goes away immediately if i put in the clutch or step off the gas. the ticking isn't there at idle.
would valves or injectors tick only under load and not at idle?
and the big question:
<U>could this be anything other than bottom end noise?</U>
Old May 11, 2004 | 11:05 AM
nub's Avatar
nub
Default Re: please help! ticking under load from d16z6 (serious)
detonation maybe?
Old May 11, 2004 | 11:08 AM
mister2racer's Avatar
sounds like it could be an exhaust leak?
Old May 11, 2004 | 11:17 AM
chronodyne28's Avatar
Default Re: please help! ticking under load from d16z6 (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote">detonation maybe? </TD></TR></TABLE>
That's what it sounds like. Maybe its time for a new fuel filter?
Old May 11, 2004 | 11:18 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote">detonation maybe? </TD></TR></TABLE> sure is, especially if it is distinctly under LOAD.
Old May 11, 2004 | 11:30 AM
SOHC_MShue's Avatar
yea my car ticks because of my zex cam, but it does it at idle too so i'm guessing its not your valve's.
Old May 11, 2004 | 12:33 PM
RyanEJ8's Avatar
I'd go ahead and check your valve clearance. If it's in spec you probably are hearing some knock.
Old May 11, 2004 | 01:04 PM
serious's Avatar
it's not detonation, my mechanics would have picked up on that. it's also definitely a tick and not a ping.
Old May 11, 2004 | 01:29 PM
nub's Avatar
nub
the only thing i can think of is to try and simulate the conditions that cause the noise and at the same time isolate where the sound is comming from. easier said than done i know. two possible ways, a chassis dyno wich some garages do have but instead of using them to measure hp and tq they use for emisions testing or diagnostic test where the drive train needs to be moving or loaded like yours. you may not be able to find or afford this. another way of doing something near the same (but with more issues as far as safety) thing would be to get the front wheels off the ground and the car securely on jack stands. then you could put the car in gear and use the brakes to load the engine while giving it gas. someone could be at the front of the car and maybe pinpoint the are the sound is comming from. if you choose to do this please,please,please be carefull
Old May 11, 2004 | 01:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by serious &raquo;</TD></TR><TR><TD CLASS="quote">it's not detonation, my mechanics would have picked up on that. it's also definitely a tick and not a ping.
It could also be your valves due to your timing being off. I don't hear about that cause often but it has happened.
HATCHingMN's Avatar
dont forget the check your heat shields!! Noises on the exhaust heat shield can vibrats and mistaken for something else!!
Old May 11, 2004 | 02:07 PM
jbs's Avatar
jbs
Default Re: (mister2racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mister2racer &raquo;</TD></TR><TR><TD CLASS="quote">sounds like it could be an exhaust leak?</TD></TR></TABLE>
This would be my guess. I have the same problem. Only happened when I installed an SC. Guess more airflow has finally found another way out of my old exhaust.[
Old May 13, 2004 | 08:25 AM
serious's Avatar
Default Re: (jbs)
wow. i never even figured exhaust could make a ticking sound.
would this only be a leak from the exhaust manifold gasket, or could i be anywhere in the system?
could it also account for a rough idle?
finally, if it's not an exhaust leak, what are my other possabilities?
Old May 28, 2004 | 08:42 AM
teal_dx's Avatar
Default Re: (serious)
I have the same sound And I replaced exhaust gaskets only to still have it there. The ticking did sound like a pinhole in the exhaust but the tone did not change with RPM's. I just adjusted valves a couple months ago. I put my ear by the motor and revved and the injectors were not making excessive noise. Like you the noise is most apparent under a load, and is not noticible at low RPM. I would like to figure this out, car sounds like *** from the outside!!
Old May 28, 2004 | 04:40 PM
PolySquared's Avatar
Default Re: (teal_dx)
I'm GOING through the same exact problem. I don't hear the tick noise at idle, but I hear it once I put the car under slight load. The tick gets louder as I put more of a load. No smoke is coming out, no coolant loss, no smoke! The noise does make my car sounds like ***. I highly doubt it would be detonation because I recently had my car nicely tuned and there is no pinging sound. Some help would be most appreciated. Thanks
Old May 28, 2004 | 09:20 PM
saboteurEK's Avatar
I get this noise too, and my wife's Concerto although we don't have that car anymore. Could it be injectors or tappets? I'd really like to eliminate this noise! Has only started happening recently (since about 120,000km) on mine.
CO_CReX
Oct 12, 2006 08:01 PM
herath22
Aug 7, 2006 03:09 PM
LilCivic04
Jan 13, 2006 06:05 PM
Clean.CL
Jan 29, 2005 09:44 AM
auburnBoy
May 5, 2004 01:44 PM
