99 Si Brakes on 93 Cx (searched)
Old May 11, 2004 | 06:29 AM
mrnicolas's Avatar
Default 99 Si Brakes on 93 Cx (searched)
Yes, I did search and I didnt come up with anything to give me the answer I am looking for.
So, if you have everything off a 99 civic si and you want to bolt it up on your 93 cx, will it work or not? I mean everything from all control arms, knuckles, sway bars etc.
Old May 11, 2004 | 06:33 AM
99blackcivicSi's Avatar
Default Re: 99 Si Brakes on 93 Cx (mrnicolas)
front or rear?
Old May 11, 2004 | 06:35 AM
mrnicolas's Avatar
both front and rear
Old May 11, 2004 | 06:41 AM
Built to Spill's Avatar
el diablo
Default Re: (mrnicolas)
you wont be able to use the rear lca's or the front upper control arms. I know the rear lca's off of the si will be too long, and i believe the upper control arms for the front of the car bolt into the engine bay/chassis different.
Old May 11, 2004 | 06:43 AM
mrnicolas's Avatar
Default Re: (Built2Spill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill &raquo;</TD></TR><TR><TD CLASS="quote">you wont be able to use the rear lca's or the front upper control arms. </TD></TR></TABLE>
but will I be able to use everythng else and have it bolt up as easy as say a 94+ teg swap?
Old May 11, 2004 | 06:45 AM
el diablo
yes...everything else should bolt up just as easy....as long as you have all of the bolts from the SI suspension.
Old May 11, 2004 | 06:52 AM
Sliced Beard's Avatar
the front knuckles are different along with the sway bars
also the front control arms upper/lower are different
and the compensator arm bolt location on the EK trailing arm is different than the EG trailing arm
also the upper control arm bolt location on the trailing arm is in a different location
mrnicolas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill &raquo;</TD></TR><TR><TD CLASS="quote">yes...everything else should bolt up just as easy....as long as you have all of the bolts from the SI suspension.</TD></TR></TABLE>
I think I can get a hold of all of that.
here is exactly what I am looking at picking up.
Front Knuckles
-rotors
-calipers
-brake lines
Front Lower Control Arms
Front Shocks w/Springs
Front Sway Bar
Rear Trailing Arms
-rotors
-calipers
-brake lines
Rear Lower Control Arms
Rear Shocks w/Springs
Rear Sway Bar
Old May 11, 2004 | 06:59 AM
el diablo
and an extra person to bleed the brakes.
Old May 11, 2004 | 07:01 AM
mrnicolas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill &raquo;</TD></TR><TR><TD CLASS="quote"> and an extra person to bleed the brakes.</TD></TR></TABLE>
got that
Old May 11, 2004 | 07:55 AM
mrnicolas's Avatar
so basically for the rear I need to get different ebrake cables and use my lower control arms or get some teg rear lower arms so I could use the rear sway?
any problems bolting it up in the front with the hub sizes and sway bar?
Old May 11, 2004 | 08:00 AM
el diablo
exactly....or you could drill a hole in your stock rear lca's to fit the rear swaybar. Other than that you shouldn't run into any problems.
Old May 11, 2004 | 08:05 AM
mrnicolas's Avatar
sweet, if anyone else ahs any input, please feel free to help me out. thanks in advance.
Old May 11, 2004 | 10:56 AM
norcalcrx's Avatar
Bump for any more info.
Old May 11, 2004 | 11:11 AM
owen_the_soyboy's Avatar
this is all you need, and actually this is all you could use---&gt;
<U>Front Knuckles</U>
-rotors
-calipers
-brake lines
<U>Rear Trailing Arms</U>
-rotors
-calipers
-brake lines
-parking brake cables
Old May 11, 2004 | 11:24 AM
teamsol's Avatar
Default Re: (owen_the_soyboy)
how about using the 99si master cyl, brake booster, and prop valve? could those also work on an eg?
zeroek
May 29, 2011 06:51 PM
richboi
Apr 1, 2009 03:10 PM
ecl-ricochet
Apr 18, 2006 08:42 PM
stickyfingers
May 9, 2005 09:40 PM
red civic standard
Oct 1, 2004 10:19 AM
