99 Si Brakes on 93 Cx (searched)
Yes, I did search and I didnt come up with anything to give me the answer I am looking for.
So, if you have everything off a 99 civic si and you want to bolt it up on your 93 cx, will it work or not? I mean everything from all control arms, knuckles, sway bars etc.
Re: (mrnicolas)
you wont be able to use the rear lca's or the front upper control arms. I know the rear lca's off of the si will be too long, and i believe the upper control arms for the front of the car bolt into the engine bay/chassis different.
Re: (Built2Spill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill »</TD></TR><TR><TD CLASS="quote">you wont be able to use the rear lca's or the front upper control arms. </TD></TR></TABLE>
but will I be able to use everythng else and have it bolt up as easy as say a 94+ teg swap?
Re: (Built2Spill)
the front knuckles are different along with the sway bars
also the front control arms upper/lower are different
and the compensator arm bolt location on the EK trailing arm is different than the EG trailing arm
also the upper control arm bolt location on the trailing arm is in a different location
Re: (Built2Spill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill »</TD></TR><TR><TD CLASS="quote">yes...everything else should bolt up just as easy....as long as you have all of the bolts from the SI suspension.</TD></TR></TABLE>
I think I can get a hold of all of that.
here is exactly what I am looking at picking up.
Front Knuckles
-rotors
-calipers
-brake lines
Front Lower Control Arms
Front Shocks w/Springs
Front Sway Bar
Rear Trailing Arms
-rotors
-calipers
-brake lines
Rear Lower Control Arms
Rear Shocks w/Springs
Rear Sway Bar
Front Knuckles
-rotors
-calipers
-brake lines
Front Sway Bar
Rear Trailing Arms
-rotors
-calipers
-brake lines
Rear Sway Bar
Re: (Built2Spill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill »</TD></TR><TR><TD CLASS="quote"> and an extra person to bleed the brakes.</TD></TR></TABLE>
got that
got that
so basically for the rear I need to get different ebrake cables and use my lower control arms or get some teg rear lower arms so I could use the rear sway?
any problems bolting it up in the front with the hub sizes and sway bar?
Re: (mrnicolas)
this is all you need, and actually this is all you could use--->
<U>Front Knuckles</U>
-rotors
-calipers
-brake lines
<U>Rear Trailing Arms</U>
-rotors
-calipers
-brake lines
-parking brake cables
-rotors
-calipers
-brake lines
-rotors
-calipers
-brake lines
richboi
04-01-2009 03:10 PM
stickyfingers
05-09-2005 09:40 PM
red civic standard
10-01-2004 10:19 AM
