what's the best ecu to use in a '98 civic ex w/ '00 si b16?
Old May 10, 2004 | 09:28 PM
98k20ex's Avatar
Default what's the best ecu to use in a '98 civic ex w/ '00 si b16?
a few weeks ago i put a b16 out of a 2000 civic si in my '98 civic ex coupe and am still using the original d16 ecu. i have the the si ecu that came with the motor but have heard of alot of people switching to obd1. what's the best way to go?
Old May 10, 2004 | 09:29 PM
dohcMONSTER's Avatar
Default Re: what's the best ecu to use in a '98 civic ex w/ '00 si b16? (98b16ex)
either reprogram your d16 ECU or go OBD I, i would just reprogram your d16
Old May 10, 2004 | 09:32 PM
MPower332TI's Avatar
Default Re: what's the best ecu to use in a '98 civic ex w/ '00 si b16? (sohcMONSTER)
I would go ITR ecu if you can find one or your next choice to stay obd 2 would be a GSR ecu.
Old May 10, 2004 | 09:33 PM
98k20ex's Avatar
what's the best car to get an obd1 ecu from? if i use obd1 will i have any problems such as check engine or airbag lights?
Old May 10, 2004 | 09:36 PM
If you go obd1 you will have to get an obd1 converter. Then i would get a p30 ecu. del sol vtec.
Old May 10, 2004 | 10:03 PM
warwagon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">either reprogram your d16 ECU or go OBD I, i would just reprogram your d16</TD></TR></TABLE>
last time i checked you can't program obd2 chief!!!!
edit: i have a p30 i will sell you for 150 shipped!!! hit me up!!
Old May 11, 2004 | 01:08 AM
CTL's Avatar
CTL
Default Re: what's the best ecu to use in a '98 civic ex w/ '00 si b16? (warwagon)
use an obd2 to obd1 jumper, with a chipped p28 ecu or p30, or obd2a p30 from a 96-97 del sol vtec.
Old May 11, 2004 | 05:51 AM
12 oz.'s Avatar
Default Re: what's the best ecu to use in a '98 civic ex w/ '00 si b16? (CTL)
https://honda-tech.com/zerothread?id=678895
ek4door1987
Apr 24, 2014 09:58 AM
baaw1554
Apr 2, 2014 05:53 PM
EcRzFinesT
15
Oct 10, 2009 10:25 AM
underdog_racer
Nov 11, 2007 08:52 PM
