i spun a rod bearing....is it possible to fix
Old May 10, 2004 | 09:19 PM
ensracer's Avatar
Default i spun a rod bearing....is it possible to fix
i have an h22a4 and i spun a rod bearing...it does not look to bad... i am just wondering if the crank could get turned and buy new rod bearings?
Old May 11, 2004 | 03:51 AM
yellow_jacket's Avatar
Default Re: i spun a rod bearing....is it possible to fix (eduardo)
It is possible. You'll just have to take it to the machine shop and let them see if they can fix it. I've had quite a few fixed, but my lude crank was beyond repair. And it didn't look that bad.
Old May 11, 2004 | 11:17 AM
ensracer's Avatar
i see,,, were gonna remove it and take it to the machine shop and we will see.....thanks
Old May 11, 2004 | 12:13 PM
Old_Nocturnal's Avatar
I tried to get a '99 crank turned but they melted it. Not sure who's fault that was, though...
What year is your car? I have a '95 H22 crank sitting in my shop I need to part with if you can use it and / or wind up needing one...
Old May 11, 2004 | 04:34 PM
satan_srv's Avatar
Default Re: i spun a rod bearing....is it possible to fix (Nocturnal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nocturnal &raquo;</TD></TR><TR><TD CLASS="quote">I tried to get a '99 crank turned but they melted it. Not sure who's fault that was, though...
What year is your car? I have a '95 H22 crank sitting in my shop I need to part with if you can use it and / or wind up needing one...</TD></TR></TABLE>
it probably won't fit...but maybe it's a 97
Old May 11, 2004 | 05:03 PM
ensracer's Avatar
mine is a 2001 block that i wanna get turned and put oversize bearing but not gonna take to the shop till thursday
Old May 14, 2004 | 07:03 PM
vinuneuro's Avatar
Default Re: (eduardo)
how much does it actually cost to fiix a spun rod bearing? It doesnt sound like a very pleasant thing to fix.
Old May 15, 2004 | 04:19 AM
Default Re: (vinuneuro)
The actual machine shop doesn't charge that much. I think it was about $150 for the last crank I had done. The only bad part is that the entire motor has to be torn down to do it. So if you are not doing it yourself it can get costly.
Old May 15, 2004 | 10:27 AM
Matgallis's Avatar
Default Re: (yellow_jacket)
Don't you just have to drop the oil pan and work from there?
Old May 15, 2004 | 03:05 PM
Default Re: (Matgallis)
Unfortunately it cannot be done without removing the tranny and flywheel. There is a housing for the rear main seal and front main seal that must be removed to remove the crank. I have done just the crank and left the pistons in place, but it still required removing the motor due to the rear main seal housing.
japscrap
Jan 31, 2009 07:11 PM
planetstereo
Sep 29, 2005 04:02 AM
hondacrxhf_3
Jun 7, 2005 06:33 PM
91hatchcivic
May 9, 2004 08:49 AM
92LudeSR
Jul 11, 2003 07:09 AM
