VTM signal on vafc
I am rewiring my vafc cuz i am having problems with my vtec, and was just wondering what the VTM signal is? any ideas.... I am also throwing a cel 22 (oil pressure switch) do i need to replace the switch or was it because i was low on oil and will fix itself.
You need to hook up the vtm wire when you are wiring up the vafc. Also if you are throwing a code it may be cause the vtm wire is not connect or that you have the vtec wires wrong....make sure the wiring is right.
topsekret
Dec 24, 2002 01:22 PM
VTECHGSR
Oct 16, 2001 05:23 PM
