Mini Me distributor question please answer!
Old May 10, 2004 | 03:08 PM
simplypinoyy's Avatar
Default Mini Me distributor question please answer!
I have heard that you can use the D15b7 Distributor but others say that you cant .... Im doing my swap in 2 days (wednesday) and I need to findout by then before i get a y8 distributor... please answer... Can a d15b7 distributor be used on a y8 head... yes or no?
Old May 10, 2004 | 03:29 PM
Default Re: Mini Me distributor question please answer! (simplypinoyy)
bump..... need answer.....
Old May 10, 2004 | 05:26 PM
Nerologic's Avatar
YES you can use it, but u have to modify the legs in order to do so, i will do a write up this eventually but i havent had a chance....dont listen to peopel that say it doesnt work, becasue IT DOES the car will run liek crap and the distro will only be held by one distro bolt but the car will run...thats what matteres right??
Old May 10, 2004 | 07:27 PM
Default Re: (Nerologic)
so it wont fit that well just w/ one bolt ? what modifications would i hafta do to it ?
Old May 10, 2004 | 07:52 PM
Ignitecivic's Avatar
Default Re: (simplypinoyy)
it will fit perfectly man. all three bolts. i tried it myself on my y8 head. i was using the d15b8 dizzy which it should be the same as the b7 dizzy.
Old May 10, 2004 | 08:18 PM
Default Re: (Ignitecivic)
what motor is the d15b8 distributor on ?
Old May 11, 2004 | 07:35 AM
NextGenRacing's Avatar
Forget the stock distributor swap. Drop $85, and get an MSD Cap with external Blaster 3 coil.
Old May 11, 2004 | 10:02 AM
Default Re: Mini Me distributor question please answer! (NextGenRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplypinoyy &raquo;</TD></TR><TR><TD CLASS="quote">what motor is the d15b8 distributor on ?</TD></TR></TABLE>
its the civic cx motor.
Old May 11, 2004 | 01:03 PM
Nerologic's Avatar
EDIT: My mini was D16Z6 head...the bolt pattern is different
d serious
Jan 8, 2010 10:03 AM
d15b7racer
Jan 7, 2005 04:26 PM
blackdc
Nov 2, 2004 05:35 PM
98civicdude
Oct 22, 2004 11:09 AM
CRX_Control
Aug 4, 2004 03:20 PM
