Starter clicks
Old May 10, 2004 | 02:11 PM
MugenAccordSedan's Avatar
Default Starter clicks
I have an H22a4 in a 95 Accord. The car does not always start the first time I turn the key. Most of the time it will click for a few times then finally start. What could be the problem. The car always starts, it just takes a few turns of the key to fire up. THANKS.
Old May 10, 2004 | 02:43 PM
fw190bvi's Avatar
Default Re: Starter clicks (MugenAccordSedan)
shitty fuel sending/delivery system cant get enough gas in the first few times to start combustion, and has to take a few clicks to prime it all???
theres ALOT of reasons it could not be startin
Old May 10, 2004 | 03:28 PM
jerry5150's Avatar
My 94 did the same thing and it turned out to be a bad winding in the starter, so it needed each turn of the key to turn the good windings into the right position to fire the solenoid. Went to pep boys and had them test it to make sure. Bought a new one and replaced it that morning.
Old May 10, 2004 | 03:29 PM
YZF_R1's Avatar
Default Re: Starter clicks (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">shitty fuel sending/delivery system cant get enough gas in the first few times to start combustion, and has to take a few clicks to prime it all???
theres ALOT of reasons it could not be startin</TD></TR></TABLE>
He said it just clicks. If that was the case then it would turn over, but not start. Check the ground to your starter. It could be loose. Also check your other grounds.
Bartman201
32
Oct 23, 2005 06:03 PM
oldschoolfreak
Jan 16, 2005 08:25 PM
SalmanzCivic
Jan 4, 2005 09:14 PM
KingJeff
Dec 12, 2004 05:48 AM
xoutlawz00x
12
Jul 31, 2004 09:40 PM
