help; ques about injector selection
Old May 10, 2004 | 12:21 PM
Shambro84's Avatar
Default help; ques about injector selection
i have a B17 swap in my 92 civic hatch stock harness what type of injectors would be best for this set up and what would my choices be from first choice to last choice(best to worst) ... thanx to all who reply.
Old May 10, 2004 | 12:35 PM
LSVtecEK1's Avatar
Default Re: help; ques about injector selection (Shambro84)
if its a stock motor, then use stock injectors.
Old May 10, 2004 | 01:03 PM
Shambro84's Avatar
Default Re: help; ques about injector selection (AllMtrADVAN)
but i can't get the stock b17 injesctor to plug into my stock civic dx engine harness. what stock honda injectors would plug into my harness. thanks!
Old May 10, 2004 | 01:09 PM
b16ahybrid's Avatar
Go find some new plugs from a 92-92 integra and splice them in.
I thought the b17 was obd-1, if so they should be the same clips. You can always use the ones from your old engine I believe they are both going to be 240cc.
Old May 10, 2004 | 01:11 PM
LSVtecEK1's Avatar
Default Re: help; ques about injector selection (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">Go find some new plugs from a 92-92 integra and splice them in.
I thought the b17 was obd-1, if so they should be the same clips. You can always use the ones from your old engine I believe they are both going to be 240cc.</TD></TR></TABLE>
Ya, it is obd1 so they should clip right on, but if not for some reason, just get an obd2 plug and splice it. Obd2 injector clips are way easier to work with anyways.
95JDM
Mar 7, 2008 12:52 PM
aaaallll04
Sep 26, 2007 12:25 AM
b18c-rex
Nov 23, 2003 02:17 PM
Chuckles
Nov 14, 2001 02:22 PM
