Which is better a 3inch straight pipe or open downpipe for my setup?
Old Nov 5, 2001 | 12:25 PM
guyuenvy's Avatar
Default Which is better a 3inch straight pipe or open downpipe for my setup?
I'm planning on getting acustom 3 inch straight pipe made to bolt on tot he cat for the track. I have a 2001 gsr sedan with greddy turbo kit. Will that be better then just having a open downpipe or should I just use open downpipe. Right now I'm using factory exahsut on normal city driving. Can't stand the noise but at the track I just drop the exhaust. Which is better 3inch straight pipe or open dp. Thanks
Old Nov 5, 2001 | 01:29 PM
PureTeg420's Avatar
Default Re: Which is better a 3inch straight pipe or open downpipe for my setup? (guyuenvy)
Open downpipes are illeagle to use at any of the tracks around here, make sure they will let you run with an open downpipe. But in response to your question, depending on your setup you should free up a couple hidden hp..
Old Nov 5, 2001 | 01:34 PM
Dublocivic's Avatar
Default Re: Which is better a 3inch straight pipe or open downpipe for my setup? (PureTeg420)
3 inch open DP. <grin> The more it flows the better it goes with turbos..eheh. remember that ryhme and you'll go faster.
Old Nov 5, 2001 | 01:36 PM
Anthony K's Avatar
New User
At the track here in Sacramento, I believe an open downpipe would surpass the 95decibel sound level limits. Might be the same at your track.
Old Nov 5, 2001 | 03:51 PM
Etylorcen's Avatar
Default Re: Which is better a 3inch straight pipe or open downpipe for my setup? (Anthony K)
Damn there is a 95db sound limit there? Thats the legal limit on the streets!
Old Nov 5, 2001 | 05:13 PM
Anthony K's Avatar
New User
Default Re: Which is better a 3inch straight pipe or open downpipe for my setup? (Etylorcen)
Actually 95db's within a certain distance. (probably pretty far)
b16psi
Mar 8, 2008 09:45 PM
PINKS
Jan 1, 2006 11:14 AM
opto_isolator
Jul 31, 2004 10:14 PM
JJFreshy
Jul 15, 2003 12:08 PM
B17aTrbo
Nov 16, 2001 08:53 PM
