99-00 SI spring rate vs: 00 EX
Old May 10, 2004 | 09:30 AM
wilsel's Avatar
Default 99-00 SI spring rate vs: 00 EX
Anyone know if the SI spring rate differs from a 00 EX? What about ride height?Would it be worthwile to replace the OEM EX springs with some from an SI if they were free?
I've already searched, and all I find are FS threads, or threads about other SI's
Modified by wilsel at 6:46 PM 5/10/2004
Old May 10, 2004 | 09:47 AM
boost junky 71's Avatar
Default Re: 99-00 SI spring rate vs: 00 EX (wilsel)
I think gsr springs would lower your car and are stiffer. That may be the way you want to go. I'm not sure on this.
Old May 10, 2004 | 10:38 AM
12 oz.'s Avatar
ride height will be so close to compare it might not be even worth it
Old May 10, 2004 | 10:54 AM
variablevalve's Avatar
Default Re: 99-00 SI spring rate vs: 00 EX (12 oz.)
try it and tell us how it goes for future reference. i mean if they're free all you lose is time right?
Old May 10, 2004 | 11:07 AM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know if the SI spring rate differs from a 00 EX? What about ride height?Would it be worthwile to replace the OEM EX springs with some from an SI if they were free?</TD></TR></TABLE>
According to clubsi.com, front/rear are. . . .
Si: 201/99.8
EX: 165/80
Old Nov 1, 2004 | 03:21 AM
hondasport2000's Avatar
Default Re: 99-00 SI spring rate vs: 00 EX (e'sd16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e’sd16 &raquo;</TD></TR><TR><TD CLASS="quote">I think gsr springs would lower your car and are stiffer. That may be the way you want to go. I'm not sure on this.</TD></TR></TABLE>
ive heard of/seen teg springs actually raise civics.
Old Nov 1, 2004 | 03:59 AM
sohc_boy's Avatar
Default Re: 99-00 SI spring rate vs: 00 EX (hondasport2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasport2000 &raquo;</TD></TR><TR><TD CLASS="quote">
ive heard of/seen teg springs actually raise civics.</TD></TR></TABLE>
same with the si springs, best bet if you want an oem spring is a set from an itr.
TwoFaced
15
Jan 17, 2011 03:00 PM
redvtec00
Suspension & Brakes
Feb 23, 2006 08:49 PM
redvtec00
10
Feb 23, 2006 03:41 AM
stackz
Nov 28, 2004 06:20 PM
mushu315
Oct 31, 2004 07:18 PM
