first gear problem
Old May 9, 2004 | 08:04 PM
blackflag188's Avatar
Default first gear problem
First off I have a sloppy *** shifter, like i can move it side to side like its in neutral or something when its in gear. And another problem im having is just finding first gear sometimes. It seems to be the most pain when im coming to a stop sign or something, I usually end up just go into second gear then on up to first. But i was probably going to change out my shift bushings and check out the shift linkage bar, you guys think that could fix my problem or what?
chris
Old May 9, 2004 | 08:08 PM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: first gear problem (blackflag188)
make sure you shift linkage isnt bent or something.
Old May 9, 2004 | 08:19 PM
Default Re: first gear problem (2ndchancehonda)
yea ill check that out
Old May 9, 2004 | 11:00 PM
The Internet Tough Guy's Avatar
when you're under there, check to make sure that the bitch pin is in place in the linkage. a lot of shops don't feel like messing with that pin and put a bolt in there instead.
https://honda-tech.com/zerothread?id=785709
NOOdS
Apr 20, 2009 11:04 AM
civic92si
Mar 31, 2007 08:34 AM
wushubrian
Feb 4, 2005 04:36 PM
wushubrian
Feb 4, 2005 02:23 PM
iMaGin
Apr 22, 2004 12:53 PM
