how to get motor on TDC?
Old May 9, 2004 | 06:49 PM
endlessdv's Avatar
Default how to get motor on TDC?
Whats the best way to get a motor on TDC?
Old May 9, 2004 | 07:01 PM
92civeg's Avatar
Default Re: how to get motor on TDC? (siamturbo)
turn the crank pulley with your 19mm
Old May 9, 2004 | 10:59 PM
All Toda Dc2
Guest
Posts: n/a
Default Re: how to get motor on TDC? (92civeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg &raquo;</TD></TR><TR><TD CLASS="quote">turn the crank pulley with your 19mm</TD></TR></TABLE>
Yup, Counter-clockwise. till cyl 1-4 pistons are at the very top.
Old May 10, 2004 | 08:31 AM
APEX CRX's Avatar
yup, I can't think of another way easier
Old May 10, 2004 | 09:05 AM
eLusive Acclude's Avatar
Default Re: how to get motor on TDC? (APEX CRX)
agreed the ghetto way is to use a screw driver stuck through the spark plug holeand watch it rise and begin to fall then you know when your there
Old May 10, 2004 | 10:24 AM
Katman's Avatar
ditton on using a 19mm socket if you have a B-series engine, and a 17mm socket if you have a D-series engine.
There's a white marker point on the crank pully which is the TDC mark, you're suppose to match-align that white marker with a marker on your timing belt cover (as seen here) to put the motor at TDC:
Old May 14, 2004 | 09:58 PM
Jon K's Avatar
Default Re: how to get motor on TDC? (Katman)
96 Prelude Si 2.3, same picture in Haynes, but how do you know you're at TDC on the right stroke? arrow on crank will line up twice, once on intake, once on exhaust, how do you make sure you're not 180* off? Popped my DOHC belt, trying to align crank, cams are easy to align, want to make sure I'm not 180* off after all this work. Thanks Jon
Old May 15, 2004 | 06:50 AM
Pondus's Avatar
Default Re: how to get motor on TDC? (Jon K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon K &raquo;</TD></TR><TR><TD CLASS="quote">96 Prelude Si 2.3, same picture in Haynes, but how do you know you're at TDC on the right stroke? arrow on crank will line up twice, once on intake, once on exhaust, how do you make sure you're not 180* off? Popped my DOHC belt, trying to align crank, cams are easy to align, want to make sure I'm not 180* off after all this work. Thanks Jon</TD></TR></TABLE>
Remove the #1 cylinder spar plug so you can verify it's at TDC.
Remember the cams rotate at half the speed of the crank so 2 revolutions on the crank for the cams to make one, when the white mark on the crank pulley lines up and the TDC marks on the cams also lines up you're there
earl
Performance
60
Dec 11, 2008 11:50 AM
efinitup
10
Dec 13, 2006 01:01 PM
sickerhatch
Sep 28, 2005 06:24 PM
duececoupe2
Feb 28, 2005 08:04 PM
airwalk07143
Jul 26, 2004 08:58 PM
