Engine turns off while driving
Old May 9, 2004 | 04:00 PM
fritzi's Avatar
Default Engine turns off while driving
Hi all,
I am a new user here hoping to find some answers to a weird problem I have with my 97 accord (4cyl, no VTEC, 117k mls, auto transm.).
It happened now 3 times in 2 weeks that my engine turns off while driving. First time it happened on the freeway going 80 miles - engine stops without any unusual noise - just stops. I am rolling to the side, I try to start - engine starts and runs without any problems until a week later. I accelerate from a traffic light and again engine out. I restart - engine idles for 5 seconds and dies, i restart again - engine runs without any trouble.
Any ideas where to search for the problem (fuel?, main relay?)
thanks for help
Fritzi
Old May 9, 2004 | 04:32 PM
bill-71SS's Avatar
Default Re: Engine turns off while driving (fritzi)
2 things to look at,first has the ignition switch recall been done and then ck the main relay,most likely the switch
Old May 9, 2004 | 06:46 PM
Chiovnidca's Avatar
Default Re: Engine turns off while driving (bill-71SS)
Most likely the ignition switch. Main relays very rarely cause stalling problems.
Old May 10, 2004 | 06:47 AM
SOHCMAN's Avatar
Default Re: Engine turns off while driving (Chiovnidca)
was the recal just for the 97? or is that whole group (94-97) included??
thanks!
sohc
Old May 10, 2004 | 07:33 AM
weezo182's Avatar
Default Re: Engine turns off while driving (SOHCMAN)
ive been having the same problem in my 92 EX... the motor just cuts out and it seems that air is pushed out of the intake?
Old May 10, 2004 | 08:21 AM
under advisement's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCMAN &raquo;</TD></TR><TR><TD CLASS="quote">was the recal just for the 97? or is that whole group (94-97) included??
thanks!
sohc</TD></TR></TABLE>
Almost every honda from like 94-01 had the ignition switch recall on it. Have your local dealer run the VIN and see.
Old May 10, 2004 | 02:03 PM
CG2's Avatar
CG2
is it overheating maybe
Old May 10, 2004 | 03:02 PM
Chiovnidca's Avatar
Just 97, 98, and 99 on the Accords.
Old May 10, 2004 | 06:30 PM
weezo182's Avatar
well i found out what was wrong(on the side of the road when it broke down agin) it ends up i have an oil leek and the oil is fludding my spark plugs so looks like ill be busey this weekend fixing the oil leak... ya.....
Old May 10, 2004 | 06:41 PM
fritzi's Avatar
Default Re: Engine turns off while driving (weezo182)
thank you very much for your suggestions -
I will check the ignition switch on the weekend - I don't think the switch has ever been replaced but it actually feels solid and engine keeps running even if I push and pull on the key. I will also get a new main relay - just in case.....
'll see what happens....
Old May 10, 2004 | 06:55 PM
Riceburner247's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Most likely the ignition switch. Main relays very rarely cause stalling problems.</TD></TR></TABLE>
I 2nd that.
Old May 11, 2004 | 12:30 PM
Accord316's Avatar
Default Re: Engine turns off while driving (riceburner247)
When your car stalls, did all your dash instruments and lights turned off? If it is, I think its the ignition switch. You could buy it at autozone. A dremel to cut a groove in the head of the screw would be good and a screwdriver would help.
Old May 14, 2004 | 01:46 PM
andylauiii's Avatar
Default Re: Engine turns off while driving (Accord316)
it's the ignition switch... that's what happen to me before while i was at cherry pickings... and it dies under the heat..then restart.. after a minute...die again... so we have AAA to take the car to honda dealer..the honda people check and they said it's fine! nothing's wrong! i was like...... so we drove it back... few days later... again! so we went to another honda dealer... finally they find out that it's the ignition switch problem..and we changed it for free since it's in the recall...
sunfire
Mar 3, 2016 09:05 PM
sgrahame21
Aug 31, 2006 08:31 PM
rkrieg4
Aug 20, 2006 09:07 PM
eston02
May 16, 2006 07:26 AM
Pro-Lude
Aug 11, 2002 06:13 PM
