cutting cold air intake
Old May 9, 2004 | 12:37 PM
jdmsijdm's Avatar
Default cutting cold air intake
ok i think i might cut my aem cai so that the filter doesnt sit down on the ground. Where would be the best place to cut it and place the filter? And will doing this make me lose much power? Will the air still flow properly? Or is it going to be detrimental and actually make less power than a stock airbox?
Old May 9, 2004 | 01:19 PM
Kal's Avatar
Kal
Default Re: cutting cold air intake (jdmsijdm)
won't cut down your power too much but make sure you make a clean cut so there's less roughness to slow down the air velocity. you can cut it anywhere you choose to make it seem like it's higher up. i don't recommend cutting it so that the filter's in the engine bay.
Old May 9, 2004 | 01:23 PM
jdmsijdm's Avatar
Default Re: cutting cold air intake (Kal)
well if its not in the engine bay and its not behind the bumper, where else could it be? you mean dont cut it too high? i plan on letting the filter sit as low as it can without going back through the hole in the chassis.
Old May 9, 2004 | 01:56 PM
Kal's Avatar
Kal
yeah don't cut it too high.
Old May 9, 2004 | 02:13 PM
POE's Avatar
POE
put it right over the hole in the chassis
shpbling
Apr 14, 2014 07:45 PM
vtec95
Jan 8, 2003 04:53 PM
k193sup
May 13, 2002 08:50 AM
IntegraZ
Jul 22, 2001 08:54 AM
