Can I run turbo B16 on a P06 with Uberdata?
Old May 9, 2004 | 10:16 AM
TeamCracka's Avatar
Default Can I run turbo B16 on a P06 with Uberdata?
I have an SIR-II swap (JDM B16 second gen) and it of course came with the P30. I was surprised to find that there is no places for the jumper, caps, and resistors, and the MM74HC373N chip doesnt fit at all. The only thing that does fit is the rom and ZIF socket. I have a P06 ecu from my old D15, and that has an identical layout to the pictures I've seen of chipped ECU's.
The question is, obviously the ECU wont have the knock sensor board, but I wasnt planning on running with that anyway, so could I run my turbo'd B16 off the P06 assuming I use the Stock GSR settings and P28 timing and fuel maps in Uberdata?
Thanks
Old May 9, 2004 | 10:50 AM
2muchPSI's Avatar
Default Re: Can I run turbo B16 on a P06 with Uberdata? (TeamCracka)
You can use it but you will have to convert the P06 to a P28, basically adding vtec. It's not too hard to do, and if you search around, you can find some How-To's online.
Old May 9, 2004 | 11:53 AM
Jim Truett's Avatar
You could send me your JDM P30 and I will solder on a SMD 74hc373, 28 pin socket for the ROM and test your ECU for $30 plus return shipping.
category5 SI
Feb 20, 2008 07:57 PM
sireg6
Apr 26, 2007 05:00 PM
JinDIESEL
Aug 25, 2004 12:33 PM
TeamCracka
May 9, 2004 03:02 PM
the_0ne
Mar 30, 2004 06:04 PM
