JUST BOUGH 92 DX EG, HAVE USDM OBD2 B18C ready, quick question about the swap! (OBD1,OBD2?)PLEASE HE
Old May 9, 2004 | 01:52 AM
Revolution2zz's Avatar
Default JUST BOUGH 92 DX EG, HAVE USDM OBD2 B18C ready, quick question about the swap! (OBD1,OBD2?)PLEASE HE
Okay, I purchased a USDM B18C1 OBD2 swap from a friend of mine about 6 months ago, its from a wrecked 2000 GS-R. He gave me everything, (engine, tranny, shift linkages, mounts, engine harness still in-tact, axels) but NO ECU.
Today I picked up my baby, a 1992 Civic DX HB 5 speed.
My question is will my OBD2 engine harness plug into the existing shock tower harness in my EG? Also what ECU do I need to get for it to work with my OBD2 motor? An OBD2 ECU? Can I get an OBD1 ECU instead? I know that the harness in the 92-95 EGs will NOT plug into an OBD2 ECU correct? Its made for OBD1?
So basically, can I use an OBD1 ECU with my OBD2 engine, if not what do I need to do to make it work and what ECU should I buy? Please help, I want to start this swap ASAP. Thanks a bunch! Any other tips would be greatly appreciated!
Old May 9, 2004 | 03:58 AM
97civicdx's Avatar
Default Re: JUST BOUGH 92 DX EG, HAVE USDM OBD2 B18C ready, quick question about the swap! (OBD1,OBD2?)PLEAS
the teg engine wire harnesses are in the same spot as the civic's. You will have to run some extra wires to the harness. Find an OBD-1 P-72 and its plug and play.
Old May 9, 2004 | 06:50 AM
degooser's Avatar
search user b18c5-eh2
he has a thread on how to put a type r into an eg its basically the same thing u are doing....oh and i you cant find it search the archives too..
Old May 9, 2004 | 07:09 AM
EVILhatch's Avatar
just have kenji chip your p28 to gsr spec.
oh,and your gonna need a jdm **** throttle bracket...
karmaworks199
Nov 8, 2015 05:27 PM
fabworxs
Jan 21, 2011 06:48 AM
blackbndt
Oct 8, 2009 06:00 PM
be18see1
Apr 1, 2007 08:58 AM
vshivik
Aug 28, 2002 12:29 PM
