All motor TB's
i just wanted to get some insight on the different throttle bodies out there for bigger NA applications, say stroked B-series for instance. any pros-cons arguements, or strong points for certain makes? any help would be appreciated. im currently running a B16, going stroker to 1.9L 82mm bore. need help in the head dept. thanks in advance.
X-eric-X
X-eric-X
i would run the same saize as the outlet of the im
for example
run a 62mm tb for the itr im cuz the itr im is 62mm
64mm for the skunk2
and 65 for the aebs im
i'm running the jg 65mm tb with the aebs im which has a 65mm outlet
for example
64mm for the skunk2
gakkuken
Oct 20, 2004 09:18 PM
douglas_be
Dec 18, 2003 11:56 AM
