Skunk2 IM on GSR....TB help
Old 12-24-2009, 10:34 AM
A.R
A.R's Avatar
Default Skunk2 IM on GSR....TB help
yo guys i currently have a skunk2 intake manifold (version 1) on my B18C1.
i have 96 spec ITR cams as well. im still running the stock 60mm throttle body.
does anyone kno the inlet opening size of the old skunk2 IM?
http://www.slickcar.com/products/SkunkManifold.jpg
need some help deciding.
is it worthwile to upgrade the TB to a bigger blox 68mm TB???
or should i look to do a mod elsewhere.
Old 12-24-2009, 11:49 AM
mouab18c1's Avatar
Default Re: Skunk2 IM on GSR....TB help
go with the ITR Tb
Old 12-24-2009, 11:53 AM
FuNkDrSpOt's Avatar
The skunk2 IM should have an inlet size of 64mm.
Old 12-24-2009, 12:42 PM
A.R
A.R's Avatar
thanks for the responses yo.
the ITR TB is 62mm - i dont think thats a worthy upgrade though
i kno its better than my stock 60mm, but am i goin to feel the difference ??
Old 12-24-2009, 02:16 PM
twentyhurtz's Avatar
off the top of my head i was thinking it was 65, but 64 could be it to, i have the version 2 pro series, but i don't know if they are the same.
Old 12-24-2009, 02:34 PM
joe383's Avatar
I would not bother with a larger TB 60 is more than enough a 60 MM should flow well over 400 CFM a 1.8L at 8,000RPM and 100% VE is only pulling a little over 250 CFM the only thing it is going to do is make your gas pedal feel more touchy.
Old 12-24-2009, 02:42 PM
FuNkDrSpOt's Avatar
That's odd, because people have seen HP gains from a slightly larger TB and a skunk2 IM.
I'd have to imagine that it's partly due to the fact that while ( assuming your numbers are correct ) a 60mm can flow 400 CFM and a b18c1 only needs a max of 250, if the inlets are a little bigger it allows for an easier airflow delivery.
Old 12-24-2009, 03:03 PM
joe383's Avatar
Look at a 2.0 dodge neon the 5 speeds only have a 48mm throttle body and make around 130 HP the problem is not the TB but the intake manifold H.O. 5.0s make 225 and are 60mm the cobra makes 350 and uses a 65mm so I think 65 is over kill on a motor that’s only going to make under 200HP other parts are the bottle neck like cam and intake ports or intake manifold.
Old 12-24-2009, 05:23 PM
A.R
A.R's Avatar
ok so a 64-65mm TB would do me well on my IM then right????
if my IM inlet is 64-65mm then i should see gains.
becuz im thinkin that my stock 60mm is a bit stiffling for my intake.
Old 12-24-2009, 11:10 PM
joe383's Avatar
what else have you don to your motor besides the intake manifold?
Old 12-25-2009, 12:12 AM
racebum's Avatar
the only reason i would change the TB is to correct the way it pulls. gsr TB's look gaudy on single runner manifolds since the cable catch is sticking up. since you have an itr copy intake manifold and itr cams, the only place i would look is the valvetrain and exhaust. have you put yellow springs on the intake side and your blue gsr intakes on the exhaust yet? you should if not. there is some power to be had cutting the back off your intake and porting the runners to line up perfectly with the head, the exhaust is another power place. other than that, enjoy the car.
Old 12-29-2009, 03:28 PM
A.R
A.R's Avatar
can i bore out a gsr TB 60mm to ITR TB size 62mm??
Old 12-29-2009, 04:29 PM
Brice.Hayden's Avatar
the version 1 GSR IM is only 63mm, one bigger than OEM. I ran a 65mm TB on it and made more power and better throttle response. I wouldn't go bigger than 65.
Old 12-30-2009, 07:52 AM
SpEeDyX's Avatar
jdm itr is 64mm thats wat i got on my skunk2 im
Old 12-30-2009, 07:55 AM
A.R
A.R's Avatar
nah speedy, OEM ITR throttle body is 62mm, u mite hav an aftermarket one
Old 12-30-2009, 07:58 AM
SpEeDyX's Avatar
thats USDM, JDM is bigger then USDM. That is why my throttle body matched up perfectly with my manifold, and no its not aftermarket, i took it directly off a jdm itr head with type r intake manifold.
Old 12-30-2009, 09:30 AM
New User
Chiney K's Avatar
JDM ITR Throttle Body is 62mm
Old 12-30-2009, 09:38 AM
New User
Chiney K's Avatar
You guys need to be careful of what you're posting around here, there
will be a lot of wrong info circulating around the place if you don't.
Old 12-30-2009, 10:08 AM
not it isn't. same part number. both are 62mm. im sure your eyes can't detect a 1mm difference.
Old 12-30-2009, 11:22 AM
kulo's Avatar
i have ek9 tb(60mm)thought it was 62mm like the itr, on my gsr sk2 pro series
need to send a b16 tb to maxbore to bore it out to 64mm to match the pro series im
smokeyjpn221
04-06-2010 02:38 PM
whiteboy-dc4
08-28-2008 12:08 PM
mrmunsell
08-07-2004 04:24 PM
Big Teggie
07-05-2003 07:50 AM
LeftCorner
09-12-2002 12:59 PM
Quick Reply: Skunk2 IM on GSR....TB help
