Apex'i V-AFC Vtec Engagement Point
Old May 8, 2004 | 10:11 PM
MugenAccordSedan's Avatar
Default Apex'i V-AFC Vtec Engagement Point
I have a question about the Apex'i VAFC. If you change your L-H cam setting to say, 4800 rpm, at what rpm should you set the H-L setting? Also, what is the stock L-H and H-L settings for an H22 engine? THANKS.
Old May 8, 2004 | 10:26 PM
fw190bvi's Avatar
Default Re: Apex'i V-AFC Vtec Engagement Point (MugenAccordSedan)
i have no fawking clue....(never used one of them things, but they sure are bling)......you should definantly get that thing dyno tuned....specailly if ur running an H22.....the shop would be able to handle that and then some
Old May 8, 2004 | 10:32 PM
-RedneckDave-'s Avatar
Working
I would search in the Prelude forum to see what other people have theirs set at because there is probably the answers there.
Old May 9, 2004 | 02:04 PM
h22abuyer's Avatar
Default Re: Apex'i V-AFC Vtec Engagement Point (01accordv6)
Hey, The factory Hi/Lo switch over on the H22 is 4800rpm i do believe, and the factory ECU switches over from L-H and H-L at the same RPM. but then again, I have been wrong at times. check with the lude guys
EATIN UP UR BSERIES
Jul 5, 2004 01:06 PM
DOHCH22ACCORD
Mar 15, 2004 06:55 PM
H22CL
Feb 10, 2004 07:56 AM
Wong Wonder
Feb 8, 2003 04:10 PM
Andrea_Aunie
Aug 8, 2002 04:43 PM
