Question about running just wastegate with no boost controller.
Old May 8, 2004 | 10:00 PM
vr6chris's Avatar
Default Question about running just wastegate with no boost controller.
I'm setting up everything for my turbo project. All parts get here in a week, so I just want to sort out everything right now. I have a turbosmart manual boost controller, but I would rather not use it. I have a Tial 40mm wastegate on the way, but I dont know what bar spring comes with those. I was just thinking of buying a 1.2 or 1.3 bar spring which is approx. 17.40 psi and 18.85 psi. And for the base tune, just use the spring that comes with the wastegate which is probably around .5 bar. I really wouldnt need to change it, cuz im sure 18 psi will be enough for a while. What do you think?
Old May 8, 2004 | 10:11 PM
VNTEC's Avatar
B A N N E D
Default Re: Question about running just wastegate with no boost controller. (vr6chris)
What motor? Ur gonna be running 17psi on a newly boosted car?! Are u crazy?
Old May 8, 2004 | 10:16 PM
Hoosier Daddy's Avatar
Default Re: Question about running just wastegate with no boost controller. (VNTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VNTEC &raquo;</TD></TR><TR><TD CLASS="quote">What motor? Ur gonna be running 17psi on a newly boosted car?! Are u crazy? </TD></TR></TABLE>
What's wrong with that?
Old May 8, 2004 | 10:17 PM
VNTEC's Avatar
B A N N E D
Default Re: Question about running just wastegate with no boost controller. (Hoosier Daddy)
"And for the base tune, just use the spring that comes with the wastegate which is probably around .5 bar. I really wouldnt need to change it, cuz im sure 18 psi will be enough for a while. What do you think?"
My bad, i thought he was trying to jump the gun and start off at 18PSI
Old May 8, 2004 | 10:31 PM
vr6chris's Avatar
Sry for the little amount of info. It is a volkswagen, but i'm on the honda-tech forums quit a bit. The motor is a VR6 with JE 83mm 9:1 compression pistons, and steel headgasket lowered to 8.5:1 compression. Motor bored from a 2.8L to a 3.0L. P&P head with heavy duty valve springs. DTA P8Pro standalone engine mang. Motor already has about 2500 miles, so its nicely broken in.
Old May 9, 2004 | 07:23 AM
vr6chris's Avatar
anyone?
Old May 9, 2004 | 09:13 AM
B18 CYA's Avatar
sorry we do not help volkswagen owners...
jk ...well if you have the boost controller why not use it?
Old May 9, 2004 | 09:20 AM
G
sh!t happens.
Default Re: (c2nap)
yea i would put a boost controller on it.. but thats just my 2 cents
Old May 9, 2004 | 11:05 PM
RyanEJ8's Avatar
At that level of boost, you'll want to use the boost controller.
Old May 24, 2004 | 12:49 AM
Y2KCivicSiR's Avatar
Default Re: Question about running just wastegate with no boost controller. (RyanCivic2000)
VW
ef8_eg6
Nov 28, 2007 03:22 AM
MostlyR
Nov 15, 2004 02:02 PM
xstalkrx
Jun 29, 2004 04:47 AM
01ITR#700
Jun 22, 2003 10:01 AM
NCSTIdriver
Dec 9, 2002 07:22 AM
