Code 36, possible Bypass????
Hey guys, i have a JDM H22 in my CX hatchback
I just got rid of my EGR code 12 and the only thing left from keeping the check engine light off if the Code 36 which is for the 4 wheel steering
I guess my p13 ecu is from a car that had 4WS because im getting the code.
My question is, Is there any way to bypass this and trick my ECU so that i dont get the code 36?
Will i have to find a ECU from a car without 4WS?
well, if you do a search for code 36 you should find a bunch of info about that code. It is a ghost code and does not affect drive ability of the vehicle at all.
The only time it shows up is when you check for the codes. So there is not really any reason why you would need to get rid of the code? There is no way to get rid of code 36 but since it doesn't cause a check engine light, then there is not really any reason to do so.
